Other than "you get what you paid for" Anyone have a reason Not to buy this pair?
My personal goal would be to use it as a learning tool, prepairing for adding telemetry to my projects. But it should be usefull too. Secondary use in some project around the house, ie halloween automation, laser guided water splasher (anti-cat crap in the yard device currently in planning stage) ect.
Here's the Junk:
This package consists of two mini half-duplex wireless data transceiver modules and each such module is highly integrated with an ultra speed MCU and a powerful RF chip. With the introduction of the innovative yet higly-efficient encoding method, its anti-interference ability and sensitivity are significantly improved. Features like various channel options, ultra long transmission distance (1000 meters) or abundant interfaces (UART/TTL, RS-485 & RS-232) helps make the transmission of data of any size possible and eliminate the needs of writing transmission program and running complicated settings. A software application ("RF-Magic") is offered for free so that users can modify the settings of the module. Besides, its slim size and wide power supply range makes itself the most popular selection of many applications in different fields.
Features:
Comment by Nicholas Winkel on April 8, 2011 at 1:44am
Comment by Alex McEwan on April 8, 2011 at 3:44am
A comment I posted earlier in regards to this modem pair:
Hey, just a tip for anyone using the APC220 modules; the ENable pin on the PC side should NOT be connected (should be left floating) to the supplied USB/TTL converter. Either make an adapter that ignores this pin or snap the pin off in order to be successful at streaming data. The modules are nice, but this small mod must be done for the PC side to work properly.
Comment by Paul on April 8, 2011 at 8:26am
Comment by bGatti on April 8, 2011 at 10:25am @Nathaniel
433Mhz is common as dirt and does not (so far as I know) require anything to operate - if it did, every second garage door in the US would be pirate radio.
Comment by Alex McEwan on April 8, 2011 at 11:51am John
Did you get yours to work bi-directional ? also what range did you get
Comment by Nicholas Winkel on April 8, 2011 at 12:27pm
Hi Alex,
At the moment I haven't long distance range tested. However, at 19.2K I am getting over 30 meters through walls with stock antennae bidirectional (just like xbees though, these are not full duplex. Tx and Rx take turns). I know this doesn't sound like much, but I haven't tested for distance and I'm sure that with a tracking antenna these will suit my needs. I'll have more info when my tracker is complete. At $35, you can pick up a set and test away, too :) You MUST disconnect the EN pin though for BiX to work.
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.106 members
1279 members
671 members
183 members
182 members
Powered by
