AC3.2.1 APM 2.5 Throttle pulsates in Loiter
Hi.
I have a problem after updating AC to 3.2.1 from 3.1.5.
When in Loiter, the the speed of the motors rev up and down/pulsate quite rapidly. This was working fine when I was using previous versions of arducopter.
I have downloaded the logs, and have looked into accX, accY and accZ. These seems to be inside the range specified in the wiki at arducopter. (Log_vibrations.bin)
Please have a look at the Log.bin, and note the difference between ThrIn and ThrOut when I'm in Loiter mode.
Anyone having any idea what the problem may be?
Log.bin
Log_Vibration.bin
        • Thanks LTMNO for looking at my log. Been working on  vibrations just had a test flight
          and vibrations are better but AltHld still not good. This is my third build and never had this much problem. This frame looks like a TBS but is not TBS.    APM 2.6 (frame type set to V)
          810Kv 10x4.5 3 cell 3.2.1 FW PS: crash was just a tip over.
          2015-04-19 13-06-24.log
          • It will be pretty hard to get rid of vibrations with 810kV + 10x4.5 + 3 cell.
            I have 850kV motors + 4S and still rpm's are not high enough to keep vibrations in lower harmonics.
            How much does your copter weight?
            • @Marko
              Right now its about 4 Lb. I want to put gimbal and GoPro on board that will make it 4.5Lb.
              All my other build are 1000Kv with same 10x4.5 and 3 cell. You might be right ! I was looking at 11x4.7 props (my ESC are only good to 3 cell) I do need to set Mid_Thr up some more I have it at 550 now needs to go to 600. I might have to rethink this build.
              Thanks...............
              • Well, I got regular X with 850kV + 10x4.5 + 4s 3000mAh, loaded with gimbal + gopro2 + alexmos controller + separate camera and all telemtery + video stuff + separate FPV battery 800mAh. In total it's about 3.5 lbs.
                I think yours it a bit overweight for loadout. Maybe you should take a bit lighter battery?
                • I use a 3300ma battery. So you have the same problem as everyone else here?
                  If so have you been able to find a fix ?
                  3.5lbs is very lite for that set up . The key must be 4 cell
                  • Well, partially.
                    I got rid of most vibrations, but still performance of copter it not as good as on 3.1.5 firmware.
                    There was clue described in this article here, but I haven't tested it yet.
                    On the other hand, on tricopter (5x3 2900kv 800mAh) I have no such awful drift problem. Yes, it can change height if you intend to leave it hanging for some time (like about minute), but basically it flies well. I can not test "loiter" mode on it because it has no GPS, but "AltHold" is pretty good.
                    Key to good copter is in "coptercalc". ;)
                    Fixing the height drifting problem
                    On the third day of trying to work out why the UAV had issues with holding it’s height, we found a solution.  During research in to the problem my su…
  • Hello All,
    after restoring the 3.1.5 firmware and setting the Throttle Accel to :
    3701983643?profile=originalAnd I slightly decrease the Stab R/P to 3.5 for my 330 Hex Thorax Frame.
    I am running APM Mini 2.7.2 with :
    2300KV Tiger Motors
    S12A ESC
    5x4.5 HQ Props
    External GPS/Compass
    Everything is Calibrated and within Parameters...
    Attached is Flight 1 with Default 3.1.5 Settings and the second Flight has modified Config as shown in picture above.
    The Hex looks as follows,
    3701983660?profile=original
    This is my 7th, build and first time experiencing problems like this.  That being said, I have noticed some interesting results with Battery Readings... if someone has a moment to have a look, it would be greatly appreciated.
    Cheers!
    Flight_1.log
    Flight_2.log
    • Well, after doing about 10 flights today... tuning the APM manually, I can get a very stable Stabilize flight... very responsive... actually, the Loiter isn't that all bad either... just a little flutter up and down.  The AltHold on the other hand is not behaving.  I then proceeded to try a version even further down the chain.  Hexa_ArduCopter_3.1.2.Hex and that had the same result.  I don't think the problem is software/firmware.  I believe we/I have a hardware problem. I don't know what it could be as my logs do indicate some Power Issues from more than 0.3v difference when in fact I get 0.429v delta.
      I am going to start with my Power Module and then test again.
      Here is the latest Logs... In case anyone is interested...
      • So, here are the results of a new PM put in place....
        3702693885?profile=original
        3702693729?profile=original
        3702693750?profile=original
        • It seems to me, your power module just not have enough power.
