Admin
Add EZ Glider Wings to EZ Star
Hi all, The EZ Glider wings can be easily modified to fit on the EZ Star adding additional lift and ailerons. However there seems to be some debate over where the CG should be with the EZ Glider wings installed on the EZ Star fuse. Regards, TCIII
  • Another question came to my mind: if you already have the Easyglider wings, you probably also have its fuse laying unused somewhere. Why not just mount a pusher engine on this glider (doing that on glider was done successfully by so many) and go on instead of trying to assemble something that is not basically meant to blend?
    Example from RCgroups:
    I tried that and I've never had such a terrible flying plane. Horrible inverse yaw problems and other symptoms of a too short-coupled airframe. I suppose I should have dialed in a lot of asymmetrical throw on the ailerons, but it was all I could do to keep it in the air.
