Adding extra functions to MinimOSD
I have started to add functions to MinimOsd code.
At first i did it for myself only. Added many functions i thought i need. Then opened this thread.
after a while, Pedro and later Miguel came, and things started to happen fast. :D
They have optimised the code and added even more things to it.
They have worked hard on CT, and it became a great tool!
Thank you Bough! :)
By now MinimOSD-Extra got a pretty advanced OSD.
Here it is in action:
Added:
- Changeable unit measurement (US, metric)
- Airspeed
- Home alt
- Battery Percent
- Battery used mah
- Current Draw
- Time From Startup (cleared at takeoff to show exact flight time)
- OSD Menu
- Variometer
- Wind horizontal speed and direction, and also the average wind speed of the last few minutes.
- OSD on/off
- Switchable secound screen
- WP distance
- WP heading
- Crosstrack error
- Warning messages for Lost GPS fix, Stall, Overspeed, battery volt, battery Percent, RSSI
- Efficiency, glide distance & thermic notifier. 3 in one panel
- OSD Brightness
- HAM Call Sign
- After flight summary
- Trip distance
- Temperature
- Smoothened horizon
- Real heading
- RSSI
- Vertical speed
This functions can be turned on and off, and placed on different screens now, by the Config. tool.
Also RSSI, switching mode and channel and unit measurement, Stall speed warning, Overspeed warning, Battery warning volt, Battery percent warning, RSSI warning,  can be set in new Config Tool.
We built in a new way of setting video standards. Now OSD does not guessing anymore :). You can set it fixed from CT. It is in "Video Mode" menu.
Here is how it looks: (This video is a bit outdated, sorry. I will make a new one soon.)
The MinimOSD-Extra project is here: Link
This project is the developing version of the official Arducam OSD located here: Link
The latest stable version is: 2.2
The latest version can be downloaded from here: MinimOSD-Extra R800
Username: MinimOSD_Extra
Password: Top_Secret
CT is included. (The FW for Plane, Copter, Character upload and the character file is in the "FW & Char" directory inside CT directory)
We are sharing it to see videos you make using it! :)
Enjoy
  • Using Arduino IDE 1.0.1 I am still getting compile errors.  Says conflicting return type associated with uint8_t. Any ideas?
    There are 2 source codes in your zip file. Is the OSD the original and the beta your changes?
  • Any way to add the current value. mavlink now sends it out to the mission planner and I display it my Minimosd using the value
    osd_curr_A
    I have hard coded a lot of things I use but like what you have done with the config tool.
    Other things that you might think about adding is
    a. way to change from meter to feet, m/s to mph
    b. a way to display a message. (some of us need to display a call sign)
    Burt
  • Big Thx, it work.
    But ist also no real solution, becouse i also cant upload chars wirh this firmware.
  • I have an idea on turning OSD on and off in flight without the use of extra channels.
    I might do that next.
  • Found a bug in warnings part.
    So here is the version before.
    Minimosd_AS_KMH_RA_BP_G_Firmwarecofigtool.zip
    Source_0.5.zip
