Adding extra functions to MinimOSD
I have started to add functions to MinimOsd code.
At first i did it for myself only. Added many functions i thought i need. Then opened this thread.
after a while, Pedro and later Miguel came, and things started to happen fast. :D
They have optimised the code and added even more things to it.
They have worked hard on CT, and it became a great tool!
Thank you Bough! :)
By now MinimOSD-Extra got a pretty advanced OSD.
Here it is in action:
Added:
- Changeable unit measurement (US, metric)
- Airspeed
- Home alt
- Battery Percent
- Battery used mah
- Current Draw
- Time From Startup (cleared at takeoff to show exact flight time)
- OSD Menu
- Variometer
- Wind horizontal speed and direction, and also the average wind speed of the last few minutes.
- OSD on/off
- Switchable secound screen
- WP distance
- WP heading
- Crosstrack error
- Warning messages for Lost GPS fix, Stall, Overspeed, battery volt, battery Percent, RSSI
- Efficiency, glide distance & thermic notifier. 3 in one panel
- OSD Brightness
- HAM Call Sign
- After flight summary
- Trip distance
- Temperature
- Smoothened horizon
- Real heading
- RSSI
- Vertical speed
This functions can be turned on and off, and placed on different screens now, by the Config. tool.
Also RSSI, switching mode and channel and unit measurement, Stall speed warning, Overspeed warning, Battery warning volt, Battery percent warning, RSSI warning,  can be set in new Config Tool.
We built in a new way of setting video standards. Now OSD does not guessing anymore :). You can set it fixed from CT. It is in "Video Mode" menu.
Here is how it looks: (This video is a bit outdated, sorry. I will make a new one soon.)
The MinimOSD-Extra project is here: Link
This project is the developing version of the official Arducam OSD located here: Link
The latest stable version is: 2.2
The latest version can be downloaded from here: MinimOSD-Extra R800
Username: MinimOSD_Extra
Password: Top_Secret
CT is included. (The FW for Plane, Copter, Character upload and the character file is in the "FW & Char" directory inside CT directory)
We are sharing it to see videos you make using it! :)
Enjoy
          • The variable you could use to debug is: chan7_raw
            it is uint16_t
            Add it to any panel temporary so you can see if data is coming.
            Gábor
      • Gábor!! It's so good to see you here. I hope all is well with you and your family. I miss the great discussions we used to have on this thread. You put in so much free personal time into this project, and I appreciate you every time I fly.
        It doesn't look like anyone has risen to fill your spot after you left. The Github site is dead.
        • Hello Iskess,
          Yes it was a long time since! :)
          I cannot promise these days. I am very occupied.
          Also have a 7 month old daughter! She is my hobby now! ;)
          However i was able to build a plane but haven't fly it yet. Just showed the R/C airport to it once so they can be friends, but that was all my activity on flying since almost 2 years now. :(
          3702809819?profile=original
          But in case you are facing some unresolvable issue, contact me!
          If i am able to i will help.
          Best regards,
          Gábor
          • 100KM
            Welcome back Gábor! Good luck with your new hobby :) Hope to see you around! You're the reason a lot of us are in APM!
  • can someone compile this to run at baud 19200 or tell me where i can fine the source code for MinimOSD_Extra_R800 plane
  • For anyone looking for a firmware that utilizes the new micro board aux pins, (such as PWM RSSI!) then check out this branch.
    http://www.rcgroups.com/forums/showthread.php?t=2591835#post33865072
  • HI,
    I am trying to add the efficiency widget but I cannot see it on the OSD screen. How can i know what is the problem?
  • 100KM
    There seems to be a bug with the Config Tool V 2.4.0.1 Pre release r788 (the one that's available in the R800 download link at the top of the post).
    The tool does not open an .osd file that has Channel 8 selected for RSSI.
    I debugged this using a merge tool and as soon as I set the line: RSSI Enable Raw 0 to RSSI Enable Raw 8 The config tool can no longer access it. Workaround is to open the osd file in a text editor and change the value from 8 to 0 and save. Then, in the config tool, just change it again.
  • Is it possible to make MinimOSD show warnings which are visible for e.g. ground station (reason for arm fail, failsafe event etc)?
    • Also looking for this option.
DIY Robocars via Twitter
RT @DanielChiaJH: @a1k0n @diyrobocars @circuitlaunch And here's the final showdown! Video courtesy of @chr1sa I think I was a little faste…
6 hours ago
RT @DanielChiaJH: @a1k0n @armand_dpl @SmallpixelCar @diyrobocars @circuitlaunch I use @foxglovedev Foxglove Studio for my visualization nee…
6 hours ago
6 hours ago
RT @a1k0n: @DanielChiaJH @diyrobocars @circuitlaunch Here's my car's view of that race. About 8.4 second lap times for laps 2 and 3... both…
Monday
RT @DanielChiaJH: Great racing against @a1k0n today at @diyrobocars! Pretty cool to both break sun-9s at the track today I think I got very…
Sunday
Broadcasting the @circuitlaunch race live now at https://m.twitch.tv/diyrobocars Races begin around 2:00pm PT
Saturday
RT @a1k0n: ran a huge number of hyperparameter tuning experiments yesterday; now I can train a new policy, far with better quality, in 15 m…
Saturday
RT @a1k0n: Did I get rid of hand-tuned parameters? Yes. Am I still hand-tuning more parameters? Also yes. I have a few knobs to address the…
Sep 26
RT @a1k0n: I'm not going to spoil it, but (after charging the battery) this works way better than it has any right to. The car is now faste…
Sep 26
Sep 26
Sep 24
Sep 24
Sep 24
Sep 23
Sep 22
Sep 11
