I have started to add functions to MinimOsd code.
At first i did it for myself only. Added many functions i thought i need. Then opened this thread.
after a while, Pedro and later Miguel came, and things started to happen fast. :D
They have optimised the code and added even more things to it.
They have worked hard on CT, and it became a great tool!
Thank you Bough! :)
By now MinimOSD-Extra got a pretty advanced OSD.
Here it is in action:
Added:
- Changeable unit measurement (US, metric)
- Airspeed
- Home alt
- Battery Percent
- Battery used mah
- Current Draw
- Time From Startup (cleared at takeoff to show exact flight time)
- OSD Menu
- Variometer
- Wind horizontal speed and direction, and also the average wind speed of the last few minutes.
- OSD on/off
- Switchable secound screen
- WP distance
- WP heading
- Crosstrack error
- Warning messages for Lost GPS fix, Stall, Overspeed, battery volt, battery Percent, RSSI
- Efficiency, glide distance & thermic notifier. 3 in one panel
- OSD Brightness
- HAM Call Sign
- After flight summary
- Trip distance
- Temperature
- Smoothened horizon
- Real heading
- RSSI
- Vertical speed
This functions can be turned on and off, and placed on different screens now, by the Config. tool.
Also RSSI, switching mode and channel and unit measurement, Stall speed warning, Overspeed warning, Battery warning volt, Battery percent warning, RSSI warning, can be set in new Config Tool.
We built in a new way of setting video standards. Now OSD does not guessing anymore :). You can set it fixed from CT. It is in "Video Mode" menu.
Here is how it looks: (This video is a bit outdated, sorry. I will make a new one soon.)
The MinimOSD-Extra project is here: Link
This project is the developing version of the official Arducam OSD located here: Link
The latest stable version is: 2.2
The latest version can be downloaded from here: MinimOSD-Extra R800
Username: MinimOSD_Extra
Password: Top_Secret
CT is included. (The FW for Plane, Copter, Character upload and the character file is in the "FW & Char" directory inside CT directory)
We are sharing it to see videos you make using it! :)
Enjoy
Thanks Nathaniel,
I will let you all know (Minus Steven G) ;) , once I get the hardware and flash the firmware, etc.
Thaks, finally found r800 19200 modified here http://www.rcgroups.com/forums/showthread.php?t=2037442&page=52
Hello, could be possible to get the sources of r800, i need to set the baudrate of minimOSD to 19200 for using with openLRS. Thanks
Well, I get R800 to work, what I was missing was to power both sides, 5V and 12V, in order to upload firmware. Now, on the bench, I have R800 working, but still doesn't display Autotune flight mode, the others flight modes are shown correctly. BTW I have the Apm default parameters (not the MOE parameters https://code.google.com/p/minimosd-extra/wiki/APM ) and R800 is going fine, except the Autotune display, that doesn't change from Manual, but in MP displays Autotune when I change it.
I dont think Autotune is added to r800.
Can imagine you'll be flying much in autotune anyway....as you say, just
use MP when tuning :)
That was the same that I thought. I will use Autotune just at the beginning, once I get my plane well tune up I wil change that mode, but it was visible on an older version. And thanks for the feedback Bjoern.
I already changed Apm parameters, and it didn't change nothing. Autotune doesn't display on OSD but does it on MP.
