After Calibration Motors keep beeping!
Hi!
Sorry... this is getting strange, I know.
But after I just calibrated my TX with the APM 2.5 the motors started spinning at low RPM.
I disconnected the the power source (5 V BEC) and than the battery.
Now when I connect the battery, this is happening:
https://www.youtube.com/watch?v=4W1zVOVJNHM
Thanks for your help!
Joerg
  • This apparently happens when ESC's don't think the throttle is "off".   I had one motor beeping on my hexacopter; it turns out that the ESC's are not "calibrated" the same (and vary by temperature; only crystal controlled ESC's don't), and as pointed out in the manual calibration steps, I had to give my throttle control about 6 "down clicks" of trim.   This lowered the throttle value enough so that the ESC's finally thought that the throttle was "off".
    I was able to manually calibrate the ESC, and auto-calibrate of all 6 worked fine after that.
    ->Bill
  • Joerg,
    I had a similar problem and I second what Richard said. You may want to follow the instructions for calibrating the ESCs one at a time. That was the only thing that worked for me.
    Jason
  • T3
    Try calibrating your ESCs. Your motors should never spin unless you are running a motor test from the CLI, which spins 1 motor at a time slowly or only after arming and then they should all spin with the throttle input.
DIY Robocars via Twitter
RT @DanielChiaJH: Great racing against @a1k0n today at @diyrobocars! Pretty cool to both break sun-9s at the track today I think I got very…
7 hours ago
Broadcasting the @circuitlaunch race live now at https://m.twitch.tv/diyrobocars Races begin around 2:00pm PT
12 hours ago
RT @a1k0n: ran a huge number of hyperparameter tuning experiments yesterday; now I can train a new policy, far with better quality, in 15 m…
12 hours ago
RT @a1k0n: Did I get rid of hand-tuned parameters? Yes. Am I still hand-tuning more parameters? Also yes. I have a few knobs to address the…
Monday
RT @a1k0n: I'm not going to spoil it, but (after charging the battery) this works way better than it has any right to. The car is now faste…
Monday
Monday
Sep 24
Sep 24
Sep 24
Sep 23
Sep 22
Sep 11
Sep 10
Sep 10
Sep 10
Aug 28
