Altitude loss in AUTO
Just updated to 2.9.1. Worked great in previous version.Set up a quick mission. 200 meters west, delay for 15 seconds and then RTL.Manually launched and switched to auto. The hex headed toward the waypoint but started losing altitude very rapidly. Took it back manually and landed thank god.Altitude hold works perfect. I am at a loss.Help.
  • My problem with altitude loss in auto SOLVED !!! :-D
    It was my fault...  :-/
    I had accidentally set the channel 7 option to store waypoints and on the radio my timer switch also was triggering ch 7 ...
    So every time I switched on the timer the new waypoint at zero alt. and @home pos overwrote my stored wp:s
    Michael Pls check if this is your problem as well...
    Regards Ronny Grimm
    https://storage.ning.com/topology/rest/1.0/file/get/3692731998?profile=original
  • Just found in the mission planner PDF manual that you should go full throttle when switching to AUTO... Will give it a try tomorrow...
  • Hi!
    I have the same problem with my hex and 2.9.1.
    Hovers at half throttle and climbs like a rocket at full throttle so no performance issue...
    Altitude hold perfect, within 1 m, also when flying around at reasonable speeds
    Loiters perfectly, (incredibly well.... within 50 cm...)
    RTL works ok climbs to default alt 50 m, flies home and descending
    Next test navigate...Then problems started
    Tried a lot of different missions
    examples:
    Mission with 4 wp @50 meter alt.
    AUTO in air =starts descending slowly from the current position.
    (once it flew wp 1 and 2 then descending at wp2 without proceeding to 3 and 4)
    Tried mission with auto takeoff and autoland
    AUTO takeoff = climbs a couple of meters then descending slowly
    Have Arduplane in a fixwing and it navigates perfectly.
    I´m running out of ideas...
    Need help!
    Regards
    Ronny
  • No, it's interesting in altitude hold it works perfect until you put it in auto! The alt hold sends the draft into orbit if I let it.
  • T3
    Try slowing the speed down. I get a drop when I fly with altitude hold and move quickly.
  • Hex flies perfect in stabilize mode.
    Z-accel is really good with a standard deviation around 5 (engineer here created an incredible damping system.
    altitude hold is right on and very stable.
    Question:  are we still using AGL of have we converted to MSL altitude.  Verify altitude programs MSL altitudes with waypoint assignment. Last flight I used MSL altitudes and it still dropped like a rock as if it was trying to correct a very large altitude error.
  • Desperation BUMP
  • What height was your waypoint?
DIY Robocars via Twitter
15 hours ago
RT @_JonMyer: 🚨Attention DeepRacer's including #UndergroundDeepRacer🚨 Check our our LIVE stream that including @IAM_dbro Take a few moments…
Aug 5
DIY Drones via Twitter
RT @MarvelmindMaxim: Extreme precision for 60 swarming robots. #marvelmind #autonomousrobotics #robotics #swarmrobotics #rtls #ips #indoor…
Aug 3
RT @MarvelmindMaxim: Precise (±2cm) tracking for racing boats and autonomous boats. Works outdoor and indoor. #autonomous #AutonomousVehic…
Aug 3
RT @MarvelmindMaxim: Helping PixHawk folks to fly autonomous quadcopters using PX4 and ArduPilot. https://marvelmind.com/drones/ Equally suitab…
Aug 3
RT @chr1sa: The @DIYRobocars @donkey_car virtual AI car race is starting in 15 minutes! Watch it live on Twitch https://www.twitch.tv/mossmann3333 htt…
Aug 1
RT @chr1sa: Don't miss our monthly @DIYRobocars @donkey_car virtual AI car race tomorrow at 10:00am PT live on Twitch. Head-to-head racing…
Jul 31
RT @sparkfun: Our completed tutorial on building an @NVIDIA Jetson Nano-powered @Sphero RVR gets your bot up and running via teleoperation…
Jul 30
RT @SmallpixelCar: Freeway test https://t.co/4V5tV9lhIP
Jul 29
Very small autonomous cars racing, thanks to an overhead camera: https://control.ee.ethz.ch/research/team-projects/autonomous-rc-car-racing.html
Jul 29
Jul 29
Jul 29
RT @chr1sa: Don't miss our virtual AI car race this Saturday! Real developers + virtual cars =🏎️🏎️🏎️ Head-to-head battles with thrills, sp…
Jul 28
Jul 27
RT @usashirou1: Jetson nano by Isaac Kaya #jetson https://t.co/Mu1N0CyQkN
Jul 23
RT @GPUsolution: JetRacer mady by Iflytek company #JetsonNANO #Nvidia https://t.co/MimTymIwge
Jul 23
