    • Hi Ian,
      in the hope that someone helps me with my problem above, i try to help you a bit.
      Basically, you need e.g. Arduino 1.0.6 (you can download the non-installation version if you are using a newer arduino software for something else). - In addition, just follow the manual on https://www.pjrc.com/teensy/td_download.html, you need Teensyduino to be installed on top in the directory. Then you just open the project from the download in the thread and open the main INO and programm it (compilation is done more or less automatically when you upload).
      It's not that hard in the end and you can have it done in about 10-15 minutes. Longest should be the installation.
      Cheers
      F.
      Teensyduino: Download and Install Teensy support into the Arduino IDE
  • Hi Guys
    I am sorry to be rehashing this but this thread is massive with the work that Rolf, Hector and others have put out and I just can't come to a working solution.
    I am trying to set the telemetry up on a Arduino Pro Mini (big fan of the Arduino and nav lights run on a pro mini already).
    Using Hector's port (https://github.com/rotcehdnih/Mavlink2Frsky)
    Compiled using Arduino 1.0.5-rc2 with software serial installed. (also tried with latest 1.6.0)
    Changed the code from Serial1 to Serial (Tempted to see what the Mega does as it has serial 2)
    Installed the Teensy software just in case it was a solution.
    Using Telemetry 2 on PixHawk
    Telemetry pin 2 to Pro Mini RXI
    Telemetry ground pin to Pro Mini GND
    S-Port signal taken from Pro Mini pin 6
    S-Port V+ taken from Pro Mini VCC
    S-Port GND from Pro Mini GND
    Write code to Pro Mini via UNO and uploads correctly.
    Using battery power on the drone, not USB.
    The LED on the Pro Mini lights up, then when the drone is ready to arm, the LED starts flashing quickly, like it is getting data.
    I have setup telemetry on the Taranis plus but still don't get any output.
    When the Pro Mini is not plugged into the Pixhawk, the Taranis reports no data. Plug it in and that message goes away.
    Any input would be greatly appreciated.
    Thanks,
    Ross
    Converts Mavlink packets to Frsky S.Port Useing Software serial - rotcehdnih/Mavlink2Frsky
  • Hi !
    I am trying to use this togehter with the X4R-SB (which i use with a SBUS to PPM adapter) as i can not fit an X8R in my craft.
    Unfortunately, i get really fluctuating values on A2 (the X4R already has an analog interface for the A2-Value integrated which is really handy) and no other values at all. I tried to change the definition of A2 in the following way:
    FrSkySPort.h: #define FR_ID_ADC3                0xF104
    FrSkySport:                     FrSkySPort_SendPackage(FR_ID_ADC3,adc2);
    This resolves the fluctuating values, but unfortunately all my other telemetry values are reading 0 (as they also did with the fluctuating A2). - Does anyone know what may be wrong here ? - Would it be asking too much if this could be made compatible also with the smaller receivers ?
    Cheers
    F.
    • Hi Everyone,
      sorry for asking again - has anyone tried this code with the X4R receiver ? Unfortunately, i can not figure out what to change to make it work. I would be very happy if someone could give me a hint.
      Cheers
      F.
    • Off topic: do this and you do not need an anadpter https://www.youtube.com/watch?v=7Nqr4-cbyvI
  • I am trying to add some commands to the end of the script to make landing gear retracts lower when armed and under a certain altitude.
    What format is the baro altitude numbers in? (100cm or 1m)
    • Just a warning.
      Don't use height alone. You must take in consideration vertical velocity and the time it takes the landing gear to deploy :).
      Also consider not a fixed height, but a range (between 10 and 12m as an example) otherwise you'll see lots of gear up and down commands :). Check my video at around 2:15 http://youtu.be/VLL0LMr3e5A?t=2m
      edit add: Oh and don't forget to set the landing gear down on radio failsafe. Don+t ask me how I know this last one :) :) :)
      • Ok great, thank you for your information.
        Can you share your code with me? as it looks like you have already started this and there isnt much point starting from scratch myself. Please? :)
        • I've given up on that Model script code because Arducopter will have a Landing Gear option for Arducopter 3.3.
          It still needed some more work specially adjusting the timings, as you can see on the video :)
DIY Robocars via Twitter
Videos from the ICRA autonomous racing workshop are now available: https://linklab-uva.github.io/icra-autonomous-racing/
Thursday
RT @SmallpixelCar: Prepared race track for Warm Spring Raceways @wsraceways and looking forward to test my new car at RAMS RC @ramsaicar fa…
Jun 6
RT @f1tenth: Trying out some nasty blocking maneuvers 🏎️🤖 #f1tenth #autonomousracing https://t.co/nMTstsaogM
Jun 5
May 27
RT @araffin2: I will talk this Saturday from 18:00 to 19:00 Paris time for the @diyrobocars community about learning to race in hours using…
May 27
RT @a1k0n: Luckily the infeasible hairpin problem was easily reproducible in simulation and I could test the fix before bringing the car ba…
May 26
RT @a1k0n: Another problem was that I was over-constraining the car's allowed accelerations, so it didn't think it could turn as tight as i…
May 26
RT @a1k0n: Breaking the map up into two halves worked, but I had to be more careful about separating the inner track from outer. There's se…
May 26
RT @a1k0n: Here's a datalog for my fastest lap of the day. Lap timer is tiny window lower-left. https://t.co/myrlWWrKUY
May 26
May 26
RT @a1k0n: Here was my car's POV. Man this track is confusing in first-person! After the incident my camera was all scuffed up and I was af…
May 23
RT @circuitlaunch: Loved seeing so many familiar (masked) faces at Circuit Launch today for our first in person @diyrobocars in over a year…
May 22
RT @circuitlaunch: Last but not least, mystery guest @BostonDynamics Spot took to the track @diyrobocars He enjoyed the #brazilianbbq too 😂…
May 22
RT @SmallpixelCar: Today’s race @circuitlaunch for @diyrobocars with @a1k0n Was busy in the morning and did not get a chance to tune camera…
May 22
RT @a1k0n: This was epic. My car was barely working this morning, had to make a lot of changes and extremely dirty hacks. Post-race analysi…
May 22
DIY Robocars @ Circuit Launch, 3/7/2020 https://twitch.tv/diyrobocars
May 22
