Hi all,
I just bought an FrSky Taranis for my quad copter and needed to get the Mavlink data up on the Taranis LCD telemetry display. So here is my solution using a Teensy3.1 as a converter between MavLink and the S.Port on FrSky X8R.
See attached file below...
Hi Wolke,
I modify your script to play voice of telemetry. I use the Switch D to enable/disable the voice.
I come from Taiwan, so some voices are Chinese, please ignore it:D
thank you for your script. Looking forward your new version for OpenTX 2.1
hi,
opentx 2.1 is released. this mean i will start to porting my github fork. i will create an new branch called s-c-l-v-r-t-opentx2.1. here all changes for 2.1 will made. old branch s-c-l-v-r-t is for 2.0.xx Radios only!
personally i will wait 3-4 weeks before i install 2.1 on my taranis because the high amount of bugs which is normal in an first major release. hoping for an first bugfix release in the next weeks.
if i am to be in luck, i get an second taranis in the next days for my kamera gimbal. for the gimbal only there is no problem for me to install opentx2.1. in this case i can start porting maybe in some days.
it is really hard to buy an taranis in germany. the item is currently sold out at all dealers:(.
/g
wolke
hi sir Wolke,
can you also make one for teensy 2.0? I currently use your firmware on teensy 2.0 and it works well with Arducopter 3.3 rc8. thanks again pal! :)
Clooney, do you have any documentation associated with your led control? Id be keen to know more. Cleanflight had awesome led control, then I moved to APM so lost all that. Would be great to use addressable leds to show telemetry info like armed state etc.
Hi Clooney!
Can you add a link to the branch you are using, sounds interesting...
//Affe
hi,
which mavlink library revision did you use?
/g
wolke
Great! This is long overdue and was on my todo list to try and tackle. Thanks :)
Hi Wolke,
I made some orders with this dealer:
http://www.microtechnics.eu/liste.php?categorie=FrSky&souscat=4...
It sends only on fridays to germany (drives the parcels per car to germany) but maybe its an option for you.
I got always very good service from him.
Cheers
Gregor
OK nearlly there with this. How do I get the Tarranis to play sounds for the actual flights modes and status its in. I currently have custom functions enabled.
thanks
