  • Can anyone give me any insight as to what I am doing wrong here?
    Arduino: 1.0.5-r2 (Windows 7), Board: "Teensy 3.1"
    MavLink_FrSkySPort.ino: In function 'void setup()':
    MavLink_FrSkySPort:121: error: 'FrSkySPort_Init' was not declared in this scope
    MavLink_FrSkySPort.ino: In function 'void loop()':
    MavLink_FrSkySPort:170: error: 'FrSkySPort_Process' was not declared in this scope
    • I figured it out. For some reason 7zip was creating a separate folder in the file for FrSkySPort and putting theFrSkySPort.ino in there. It still does that every time I extract the files. weird. I found an older version that extracted correctly here
      http://diydrones.com/profiles/blogs/how-to-get-apm-pixhawk-telemetr...
      then I noticed the difference in the files and just moved it where it should be.
  • This thing seems fantastic. So we can basically buy a Teensy3.1 and enjoy a telemetry link on the taranis directly from APM?
    • Is there a Pixhawk Teensy-less alternative?
      • Well hard to tell u would have to get the Pixhawk to change the Telemetry output to what the X8R could understand! and then wire it correctly!
  • I have pushed the changes I have worked on to github:
    https://github.com/chsw/MavLink_FrSkySPort/releases/tag/1.4
    Changes
     - Acc X/Y/Z reports the average vibrations (difference between max/min) instead of actual accelerometer values.
    - Reports gps-speed instead of hud-speed.
    - Change how the code responds to tx telemetry requests. This fixes the missing cell/cells in the latest open-tx versions.
    - Updated the cell detection to minimize the risk of detecting to many cells (unless the battery is low upon connection)
      and changing the cell count inflight when the battery voltage drops.
    - Changed the averaging for voltage/current to be more accurate to the voltage/current fluctuations. Hoping of increasing the
      accurasy of the mAh-counter. Use FAS as both voltage/current source.
    - Delays sending the voltage/current until the voltage reading through mavlink has stabilized. This should minimize the false
      low battery-warnings upon model powerup.
    Contribute to chsw/MavLink_FrSkySPort development by creating an account on GitHub.
    • Working well for me so far.    Would have saved me a lot of time yesterday if I had waited.   Thanks!!!
    • Hi Christian
      I assume you're using
      https://www.pjrc.com/teensy/hid_listen.html
      to debug ??
      or other way?
      brgds
      Luis
      HID Listen program, or simple text debug output with Teensy USB
      • I mostly use the built in serial monitor in Arduino actually.
        Don't really like the arduino-ide, but since I only made small changes I haven't looked into any alternatives.
  • Any update on a fix for Cells on 2.0.8?
DIY Robocars via Twitter
Videos from the ICRA autonomous racing workshop are now available: https://linklab-uva.github.io/icra-autonomous-racing/
Thursday
RT @SmallpixelCar: Prepared race track for Warm Spring Raceways @wsraceways and looking forward to test my new car at RAMS RC @ramsaicar fa…
Jun 6
RT @f1tenth: Trying out some nasty blocking maneuvers 🏎️🤖 #f1tenth #autonomousracing https://t.co/nMTstsaogM
Jun 5
May 27
RT @araffin2: I will talk this Saturday from 18:00 to 19:00 Paris time for the @diyrobocars community about learning to race in hours using…
May 27
RT @a1k0n: Luckily the infeasible hairpin problem was easily reproducible in simulation and I could test the fix before bringing the car ba…
May 26
RT @a1k0n: Another problem was that I was over-constraining the car's allowed accelerations, so it didn't think it could turn as tight as i…
May 26
RT @a1k0n: Breaking the map up into two halves worked, but I had to be more careful about separating the inner track from outer. There's se…
May 26
RT @a1k0n: Here's a datalog for my fastest lap of the day. Lap timer is tiny window lower-left. https://t.co/myrlWWrKUY
May 26
May 26
RT @a1k0n: Here was my car's POV. Man this track is confusing in first-person! After the incident my camera was all scuffed up and I was af…
May 23
RT @circuitlaunch: Loved seeing so many familiar (masked) faces at Circuit Launch today for our first in person @diyrobocars in over a year…
May 22
RT @circuitlaunch: Last but not least, mystery guest @BostonDynamics Spot took to the track @diyrobocars He enjoyed the #brazilianbbq too 😂…
May 22
RT @SmallpixelCar: Today’s race @circuitlaunch for @diyrobocars with @a1k0n Was busy in the morning and did not get a chance to tune camera…
May 22
RT @a1k0n: This was epic. My car was barely working this morning, had to make a lot of changes and extremely dirty hacks. Post-race analysi…
May 22
DIY Robocars @ Circuit Launch, 3/7/2020 https://twitch.tv/diyrobocars
May 22
