    • @Chris Song Did you tried my port?
      • I tried your code. But it's the same result that the degrees and minutes are zero. As you know just replace Serial1 from Teensy code and comments the C1,C2,C3 UARTs. I got the correct sensor values except GPS's latitude and longitude values that the degrees and minutes are zero. Do you have correct value of GPS?
        • 3702768188?profile=original
          • FrSkySPort.ino: In function 'void FrSkySPort_Process()':
            FrSkySPort.ino:33: warning: unused variable 'temp'
            FrSkySPort.ino:34: warning: unused variable 'offset'
            FrSkySPort.ino: In function 'void FrSkySPort_ProcessSensorRequest(uint8_t)':
            FrSkySPort.ino:66: warning: deprecated conversion from string constant to 'char*'
            FrSkySPort.ino:115: warning: deprecated conversion from string constant to 'char*'
            FrSkySPort.ino:133: warning: deprecated conversion from string constant to 'char*'
            FrSkySPort.ino:162: warning: deprecated conversion from string constant to 'char*'
            FrSkySPort.ino:209: warning: deprecated conversion from string constant to 'char*'
            C:\Program Files (x86)\Arduino\libraries\SoftwareSerial\SoftwareSerial.cpp:59: warning: only initialized variables can be placed into program memory area
            C:\Program Files (x86)\Arduino\hardware\arduino\cores\arduino\HardwareSerial.cpp: In function 'void store_char(unsigned char, ring_buffer*)':
            C:\Program Files (x86)\Arduino\hardware\arduino\cores\arduino\HardwareSerial.cpp:98: warning: comparison between signed and unsigned integer expressions
            C:\Program Files (x86)\Arduino\hardware\arduino\cores\arduino\HardwareSerial.cpp: In function 'void __vector_18()':
            C:\Program Files (x86)\Arduino\hardware\arduino\cores\arduino\HardwareSerial.cpp:127: warning: unused variable 'c'
            C:\Program Files (x86)\Arduino\hardware\arduino\cores\arduino\HardwareSerial.cpp: In member function 'void HardwareSerial::begin(long unsigned int, byte)':
            C:\Program Files (x86)\Arduino\hardware\arduino\cores\arduino\HardwareSerial.cpp:368: warning: unused variable 'current_config'
            C:\Program Files (x86)\Arduino\hardware\arduino\cores\arduino\HardwareSerial.cpp: In member function 'virtual size_t HardwareSerial::write(uint8_t)':
            C:\Program Files (x86)\Arduino\hardware\arduino\cores\arduino\HardwareSerial.cpp:467: warning: comparison between signed and unsigned integer expressions
            C:\Program Files (x86)\Arduino\hardware\arduino\cores\arduino\Print.cpp: In member function 'size_t Print::print(const __FlashStringHelper*)':
            C:\Program Files (x86)\Arduino\hardware\arduino\cores\arduino\Print.cpp:44: warning: '__progmem__' attribute ignored
            C:\Program Files (x86)\Arduino\hardware\arduino\cores\arduino\Tone.cpp:119: warning: only initialized variables can be placed into program memory area
            • I don't understand that you said. It's compiling warning and it's not related to GPS values. There is no GPS data in your captured image also.
              • It's compiling warning and it's not related to GPS values
                So you think the same about it.^^
    • I don't understand which files I have to use with the pro mini : I get a message when compiling with the Arduino 1.5.6.r2 version "not enough memory for variables" ?
      Could you telle me wich arduino sketch use ?
      Ed
  • Now it works ^^
    https://www.sparkfun.com/products/11113
    3701839532?profile=original
    Arduino Pro Mini 328 - 5V/16MHz
    SparkFun's minimal design approach to Arduino. This is a 5V Arduino running the 16MHz bootloader.
