Hi all,
I just bought an FrSky Taranis for my quad copter and needed to get the Mavlink data up on the Taranis LCD telemetry display. So here is my solution using a Teensy3.1 as a converter between MavLink and the S.Port on FrSky X8R.
See attached file below...
Hi
I do not understand this last post if one dos not like the price then one is not obliged to pay.
Further what is what i presume to be a racist picture doing in this forum ,and is totally inappropriate in a modern society
Tim Painter
knowyourmeme
This isn't my opinion, sry
A staggeringly stupid thing for a german to post on a moderate technology forum.
I would like to say awesome job by everyone that made this possible. I have been able to get Hector's version of the program working on an Arduino Uno for testing, but whenever I connect the Uno TX line on my APM 2.8, the APM acts like the pin has been shorted to ground. In my setup I have a telemetry radio connected to an APM 2.8, then I connected pin 0 on the Uno to the APM telemetry TX pin. When the connection is made I loose all telemetry. Interesting enough If I feed the telemetry into the Uno from my ground station radio everything works as expected and the Taranis is able to read all the information.
Any suggestions on what the issue maybe? I am hoping it is just the Uno, and when I use an Arduino Mini I will not have any issues.
Thanks, Jeff
bonjour je ne peux pas compile votre code voici l erreur pourriez vous m aide a trouve une solution?
# error Must include FastSerial.h before the Arduino serial driver is defined.
bonjour,alors avez vous pu compiler le code?peut etre que je peux vous aider
oui j aimerais si c 'est possible je ne suis pas tres bon en arduino je connais quelque base,
j ai telecharger et installe dans :
c:\program files\arduino\libraries
lors de la compilation j ai une erreur qui revient fastserail
j ai essaye de compiler avec un nano 328p ou teensy mais rien a faire toujours la meme erreur
apres plusieurs essais
j ai mis a jour mes bibliotheques mais rien ne fais
.vous etes sur facebook? ça sera facile pour ne pas poluer ce forum.mon pseudo c est "Reno-Guiza safa"
je suis pas non plus fort en arduino mais j'ai trouvé une methode plus facile et simple
ok mon speudo est :
gael ou
je vous envois un message des ce soirs merci d avances de votre coup de main
