Hi all,
I just bought an FrSky Taranis for my quad copter and needed to get the Mavlink data up on the Taranis LCD telemetry display. So here is my solution using a Teensy3.1 as a converter between MavLink and the S.Port on FrSky X8R.
See attached file below...
First, thanks to all for the amazing work done on this project!
My question, can someone advise if there is a version of the software that provides data on the Armed/Disarmed state of the flight controller to the Taranis?
Firat, i have read through most of the 100+ pages but I find myself at a bit of a loss on "where to begin". Or rather I got confused when the branches/mods showed up in the thread. :)
I get confused over some of e forks that seem based on Arduino Micro Pro in comparison to the original code.
So, here are my situation.
I have a APM 2.6 with 3DR Radio and Minimosd (Minimosd only has the APM TX connected)
I have a Taranis X9D Plus with opentx-9xdp-v.2.0.9.2
I have an X8R
I have a teensy 3.1 lying about.
Which branch etc is my best be for this? :)
Hello Jan,
take this code from here!
Works perfect for me!
Or this one but here i got problems with the storm32 bgc.
Both are for the Teensy 3.1 and working out of the box.
I grabbed the fmoopdogg package.
Hex is loaded. And I see messages on the serial console.
I have copied the files from ApmPositionDisplaynto to my Sd card. But I get nothing when log pressing menu.
Now, I will assume I need to config something to match my model names or such. I tested a bit but could not find what I needed to do.
Yes, I am a Taranis noob. :)
My model is "01" with name "Storfot". What should I change on the SD?
Thanks!
If you haven't already, you need to go into the SCRIPTS folder on the SD card and change the sub-folder "model_name" to "Storfot".
Hello!
I redid "from scratch" and renamed the "model_name" folder.
This time it worked.. .So. obviously i screwed up before :)
Thanks and appreciated!
I will investigate that branch in the comin evenings. :)
How could telemetry interfere with a Bgc?
Read here, page 87 in these Thread.
That will not apply to me. But I do appreciate you making the distinction!
