  • Had anyone tried to get the teensy running on serial4 line of the Pixhawk. I would like to have seperate connections for telemetry, osd, and the teensy. On the software side we have SR0 (telemetry), SR1 (OSD), and SR2 in my case I want to use this for the teensy. Is this possible to use it? With the defaults i got no data to telemetry.
    Gregor
  • To the guys using the wolkstein fork:
    I can't get the voltage to show the correct value. In the telemetry page where it shows every cell they're all changing from 0 to 1 values, everything else seems to be working just fine.
    I'm using the last taranis version
    • did you compile MavLink_FrSkySPort.ino from my fork?
      and did you use the single cell voltage network?
      if you compile MavLink_FrSkySPort.ino from my fork and if you don't connect the sigle cell network you must comment  line 87 & 88 in MavLink_FrSkySPort.ino. else it will read lipo cells voltage 1-6 via teensy A0-A5 inputs.
      commenting line 87 and 88 switch back, to use reported mavlink voltage.
      /g
      wolke
      • thank you very much! I think it should be this way as default or at least stated somewhere in the readme.
        Thanks again
        • now there is a small compile info inside the README.md. my fork is mainly thought to have the lipo balancer plug on teensy. else, there are some other forks with standard use. that is, why i decide to set this as default.
          /g
          wolke
          • Where should I change the values to get the correct voltage cells in my taranis? Now install the resistor network but reading is a little different, I would like to make it more accurate and do not understand what the divisor.
            • factors in MavLink_FrSkySPort.ino line 194-199.
              /g
              wolke
              • I found it, but as calculation? I do not understand that you used mathematical calculations.
                • FLVSS need valid cell voltage values. so of course all mathematical calculations will realised in teensy. the factors are needed to do this calculation. and if you use other resistors this factors must adapted. else taranis display malarkey. i am not really good in maths. if there is an other way to calculate the correct values(without simple maths) please let me know.
  • Are there some modifications to do in the arduino scetch or LUA script when upragding the taranis to opentx 2.0.14 ?
    It seems to me that some values are no more working (roll indication for example stay flat when I roll manually the vehicule) ?
DIY Robocars via Twitter
May 15
May 14
May 13
May 13
May 11
May 8
May 8
RT @SmallpixelCar: Test my car. RTK GPS worked great. Thanks @emlid for their support. https://t.co/EkQ6qmjmWR
May 8
DIY Drones via Twitter
RT @chr1sa: @kane That's @diydrones circa 2009. Still have a box of those Canon cameras that we used to strap into planes, just like this.…
May 3
RT @chr1sa: Our next @diyrobocars race is going to be outside at a real RC racetrack in Fremont on May 28. Fully autonomous racing, head-to…
Apr 30
RT @f1tenth: Our Spring 2022 F1TENTH course @PennEngineers is coming to an end with a head-to-head race as a big finale. So proud of our st…
Apr 26
RT @DanielChiaJH: I wrote a thing! Throughout the development of my @diyrobocars car I've been using @foxglovedev Studio to visualize and d…
Apr 23
RT @SmallpixelCar: My new car for high speed. Low body, everything ( @NVIDIAEmbedded Jetson Xavier NX, @emlid RTK GPS, IMC) under the deck…
Apr 23
Apr 21
RT @f1tenth: F1TENTH Race training setup @PennEngineers for our upcoming ICRA2022 @ieee_ras_icra competition. @OpenRoboticsOrg @IndyAChalle…
Apr 21
RT @fatcatFABLAB: Proud to be hosting a restarted DIY Robocars NYC Meetup April 26. Come by if you want to talk about and race self-driving…
Apr 17
