Hi all,
I just bought an FrSky Taranis for my quad copter and needed to get the Mavlink data up on the Taranis LCD telemetry display. So here is my solution using a Teensy3.1 as a converter between MavLink and the S.Port on FrSky X8R.
See attached file below...
mine is 2940
Press and hold menu on your Taranis and then Page until you see the sreen Version
There it should be something like this:
opentx-x9d-v1.1.02
Re-flashing did not help. Keep getting the -255 degrees. Flew today in a different park.
That may be an OpenTx problem of the new firmware. Maybe I should open an issue there
Try with my:
MyTaranis.bin
please see the attached picture. I am in Toronto Canada
I simulated your coordinates Lat 43.39,7740N Long 79.27.2286E on the Teensy and the Taranis shows these coordinates without a problem on my Tx.
I guess we have to see if it's works on your's after you have reflashed.
That is the newest FW that Companion downloaded for the Taranis. Build on February 2, 2014. To my knowledge there is no newer stable FW out there as of yet. I will reflash it and see if it fixes the problem
thanks
SVN: opentx-r2940
Can you give me an example of GPS coordinates from your part of the world..
Hello Rolf,
can you tell me how to retrieve RCin of channel 3 from the MAVLINK Data?
Peter
