apc220 with mp
All i am using the apc220 telemtry with apm but i am getting errors for example when trying to wire a mission i get system exception on read. Basicly reading stuff out of my arducopter with apc220 goes great but whenever i want to write (upload) it gives errors. Any ideas on how to fix this?
    Last night I attempted to give my APCs a little more breathing room to increase the reliability of configuration and telemetry actions. I have added a counter to gcs_send_message(MSG_RETRY_DEFERRED); in the main loop and it certainly helps with the consistency that parameters are both pulled and modified. See below for the modification. This is a first attempt at this type of delay mod., as my other attempts have been to simply eliminate some of the Mavlink data being sent. This should keep us fully functional.
    In ArduCopter.pde
    First, declare a new int. variable up in the declarations section. I chose   int DEFERRED_COUNT = 0; .
    Then locate gcs_send_message(MSG_RETRY_DEFERRED); and encapsulate it as follows:
    // Main loop
    static void fast_loop()
        // try to send any deferred messages if the serial port now has
        // some space available (every 10 main loop cycles. we will experiment with this value)
        if (DEFERRED_COUNT > 10){
        DEFERRED_COUNT = 0;}
        // increment the counter
        DEFERRED_COUNT = DEFERRED_COUNT + 1;
    Now I can use the Connect button every time instead of using Ctrl+T to first initiate the connection. I can also modify parameters without fail. Can you guys see if this improves your situation as well?
  • Same thing over here. I only can send write commands reliable via APC220 if no other data is being transmitted via this channel. It seems to be that 19200 bd is simply not enough for transmitting telemetry data as well as updating the configuration ...
  • i have used APC220 with APM2.24. it does writes once in a while and does not most of the times. will find a wayout whay it does so and will put a post.
