APM 2.22 Loiter problem
Hi everybody.
I'm flyng with a Bixler with APM and everything work fine from the first day.
Yesterday I've loaded the 2.22 version from the planner, and from the first flight I've had some problems.
As you can see in the attached JPG the loiter track is not a circle (like in the previous version) but is a "beans". the wind today was 0.
I've tried to reload the firmware, to reset the APM, to manually reload every value, the check every connection, but nothing to do. I've a lot of "beans".
Any suggestion?
Thanks a lot!
Emiliano.
  • Hi Chris,
    HDNG2RLL_I,5
    All problems solved.
    No more beans!!!
    Tnx a lot.
    Emiliano.
  • Hi Chris,
    In my config now I've:
    HDNG2RLL_I,0
    XTRK_GAIN_SC,100
    I've to modify it to:
    HDNG2RLL_I,100
    XTRK_GAIN_SC,100
    Thanks a lot.
    Try turning up NAV_ROLL_I and Crosstrack Gain:
    Parameter names:
    HDNG2RLL_I
    XTRK_GAIN_SC
