            • Yes, I did not mention Galileo, because when this system is operating (in 2020 ?) we will be discussing about the NEO 16 ;-)
        • big nonsense Ibrahim....that battery you see on board is to power EEprom...
          • maybe it is fake.
            see : http://code.google.com/p/i2c-gps-nav/downloads/detail?name=ublox-hw...
              @ibrahim no its not fake. For example jDrones GPSes have EEPROM installed and they also have configurations uploaded.
              Battery is not for EEPROM. Battery is for keeping Navigation almanac and last position/lock informations alive inside GPS computer. Without it getting first position locks will take much l9nger as a lot of data needs to be loaded from satellites eg. Cold boot that clears all memories on GPS computer.
  • I'm still having a lot of GPS problems with APM 2.5 with NEO-6M UBLOX GPS using fw 3.1. Got GPS errors in logs and GPS BAD HEALTH during flight
    Fw 3.0 seems OK
    This is 3.0 log
    while this is 3.1 log
    in the same place, same time, same GPS.
    When gps shows errors copter goes crazy and flies away...you need to regain control in stab
    Has anybody the same problems? Has something to do with new gps glitch protection introduced in 3.1 fw?
    • I have same problem. I took off on stabilize mode, then switched to altitude hold and then loiter, there were no problems. When i switched to auto mode it flied away to sky :) up to 165 meter. Then decided to descend but then crashed. Luckily crashed on a empty area with no damage.
      I have external gps and compass module bought from ebay. I did not changed its configuration.
    • I was getting occasional similar GPS "runaways."  Loading the NEO-6M GPS configuration posted earlier in this thread seems to help:  http://diydrones.com/xn/detail/705844:Comment:1222612
      http://diydrones.com/forum/attachment/download?id=705844%3AUploaded...
      Though it seems like I still get a "runaway" every once in a while.
      --ET
  • I'm using NEO6 GPS configured with the specific configuration file from megapirateng group.
    I've used it for some month without any problem.
    With last APMcopter releases I've got a lot of GPS errors (documented in logs) that lead copter to fly away very often.
    I've solved the problem resetting GPS to default (NMEA-9600bps).
    I noticed that, as reported by Linus, at power on APMcopter sets GPS to UBLOX protocol - 38400bps ...so I wonder if we still need to configure the GPS with 3dr.txt file (as stated in apmcopter documentation) or shall we leave GPS at defaults parameters and let APMcopter configure it.
    Luciano
    • I run a cheap $26 Chinese NEO6 unit  (with compass) as well, and left it completely standard. As long as you make sure you have plenty satellites before arming, it works perfectly well - loiter is rock solid.
  • I've just bought a $26 compass + NEO-6 unit from goodluckbuy, and - indoors - it seems to be reasonable accurate. Got sat lock in around 2-3 minutes from cold, and fluctuated between 8 and 10 sats 8 (which is the same for the LEA-6). Left it running in Mission planner for over an hour, and it was ok - didn't move about any more than the standard 3DR LEA-6.
    Also comes in a handy case with tidy cabling, and slightly longer than the standard as well, which is handy.
    I'm still not sure why NEO is so bad? Seems ok here...Are there any "gotchas" I should be wary of? I'm running arducopter 3.1.2 in quad mode.
DIY Robocars via Twitter
Apr 27
Apr 27
RT @f1tenth: Sliding (autonomously) into the weekend like ... 🤖😎 #f1tenth #robots #AutonomousVehicles @OpenRoboticsOrg @NVIDIAEmbedded @Aut…
Apr 25
RT @chr1sa: One of the problems with autonomous car racing is that watching software drive is not a very exciting spectator sport. To help…
Apr 25
RT @SmallpixelCar: Replaced AGX Xavier with @NVIDIAEmbedded Jetson Xavier NX. Now both cars look fast and clean https://t.co/jlcoY2EjZf
Apr 25
RT @chr1sa: Yesterday we had a record number of competitors (36) in our monthly @DIYRobocars virtual autonomous car race. We kept it going…
Apr 25
Apr 16
DIY Drones via Twitter
RT @chr1sa: After more than a year of only virtual races, @DIYRobocars returns to the newly renovated @circuitlaunch on May 22 for the resu…
Apr 11
RT @DAVGtech: And now available with LiDAR 🔥 https://twitter.com/Heavy02011/status/1381137016381964293
Apr 11
RT @Heavy02011: #VirtualRaceLeague: @DIYRobocars Race #9 - #ParkingLotNerds #thunderhillracetrack, CA Join us for the next race April 24th,…
Apr 11
RT @DWalmroth: Weather's finally cooperating, looking forward to racing 1:10 scale autonomous cars outdoors again! @diyrobocars, @NVIDIAEm…
Apr 7
RT @AIDRI_: I finally succeeded in optimizing the trajectory and speed of a car on a #racetrack. Next step: implement a 2d controller and…
Apr 7
@jetdillo @circuitlaunch Actually the second *in person* event in a year. We do virtual races every month
Apr 2
Update: we're moving it back one day to Sunday (the 4th) at 11:00am instead
Apr 2
@GrantEMoe @circuitlaunch Update: we're doing it on Sunday (4th) at 11:00am instead
Apr 2
RT @chr1sa: Maybe we should have a mini @DIYRobocars race in our lower school's playground https://t.co/xLFeua1R6X
Mar 29
