APM 2.6, 9XR, FRSKY, RADIO CALIBRATION HELP!!!!
I just finished building a DJI F450 with APM 2.6. All the calibrations went fine until i got to the radio calibration. It shows no stick movement like the rx isn't sending signal to the APM? I checked and double checked the connections, I even took the rx out and put it in my plane seemed to work fine. Also a link to the rx to apm channel connections would be helpful. I hope someone else has had the problem and fixed it.
           Thanks, Doug
  • Hi again Doug,
    Here is an example of Dennis' tutorial : https://www.youtube.com/watch?v=E1a08Osy7HY I found all his videos are really useful easy to follow and clear.
    Good luck Doug,
    R
  • Hi Doug,
    I don't use 9xr but Turnigy 9x and used to have similar problem until I almost gave up. All I did was de-construct all the electronics and re-construct again (with new cable) and voila! It worked well. I found some explanation from this guy:
    https://www.youtube.com/watch?v=iUahfiWcSfY and from a guy called Dennis Baldwin also in youtube are really useful. Dennis has a really clear video as well so that you know exactly how he does the cabling.
    By the way, no stick movement for both sticks (left and right) or only one of the sticks? Might be a Tx board/connection/solder issue?
    Best wishes and good luck Doug,
    R
DIY Drones via Twitter
Using ArduRover with an RTK GPS https://ift.tt/2N9I3RO
yesterday
Monday
DIY Robocars via Twitter
Monday
Friday
Friday
Jan 14
RT @Heavy02011: @diyrobocars : A Home-brew computer club* for Connected Autonomous Driving on Jan 23rd, 2021 https://www.meetup.com/Connected-Autonomous-Driving/events/275728684/ #Meetu…
Jan 14
Jan 14
David Hori liked Isabella Domi's profile
Jan 12
RT @Heavy02011: ⁦@diyrobocars⁩ Autonomous Driving Assembly at #rC3. join us at https://rc3.world/rc3/assembly/diyrobocars-f1tenth/ ⁦@f1tenth⁩ ⁦@DAVGtech⁩ ⁦@DWalmroth⁩…
Jan 11
RT @chr1sa: New car designs coming for our next @DIYRobocars @donkey_car virtual race on the 23rd. Choose any one you want at race time Le…
Jan 11
RT @RoboticMasters: Thanks to @EllerbachMaxime and the Sydney Uni Capstone Students the @donkey_car @diyrobocars simulator is getting a ma…
Jan 11
Jan 6
Dec 28, 2020
An interesting line-following simulator to use with with your robocars: https://github.com/ron-grant/LFS
Dec 23, 2020
Dec 23, 2020
