I do not know the EZUHF stuff, but equipment connected to the inputs 1-8 and connectors A0-A11 should not draw more than 500mA in sum from the APM if it is powered by a ESC or BEC connected to the outputs 1-8 and JP1 is present. However you can put more load on the APM outputs since the current is bridged over the output pins.So if you power your APM with BEC or ESC on output rail you can connect your EZUHF to any available output on GND and + pins.
Fixed wing airplane, multirotor, or rover application?
(I should have asked previously)
-=Doug
What EZUHF product are you referring to?
-=Doug
