I have ArduPilot Mega Software-In-The-Loop almost working in 64-bit Ubuntu 12.04. Only problem is that there seems to be a lack of MAVLink packet communication. Can anyone help me out?
Following is how I set up the simulation software. I hope this will serve as a tutorial once I get past that final problem.
- Open a terminal console window.
- Make a new folder for simulation software and enter the directory:
mkdir sitl
cd sitl - Install prerequisites, if missing:
sudo apt-get install git python-serial g++ autoconf libtool automake gawk
- Download MAVProxy, mavlink, JSBSim and APM:
git clone git://github.com/tridge/MAVProxy.git
git clone git://github.com/tridge/mavlink.git
git clone git://github.com/tridge/jsbsim.git
git clone https://code.google.com/p/ardupilot-mega/ - Build and install JSBSim:
cd jsbsim
./autogen.sh
./configure --enable-libraries --enable-shared --prefix=/opt/jsbsim
make
sudo make install
cd .. - Build ArduPlane and ArduCopter binaries and copy them from temporary folder:
cd ardupilot-mega/ArduPlane
make -f ../libraries/Desktop/Makefile.desktop
cd ../..
cp /tmp/ArduPlane.build/ArduPlane.elf .
cd ardupilot-mega/ArduCopter
cd ../..
cp /tmp/ArduCopter.build/ArduPlane.elf . - Install flightgear:
sudo apt-get install flightgear
Now, because JSBSim did not install it's binaries in the system folders when I ran "make install", I have to make sure that the binaries can be found by simulation scripts. As a temporary hack, I added the following folder to the $PATH variable: "~/sitl/uav/sitl/jsbsim/src". This is where the compiled but uninstalled JSBSim executable is located.
I tried to run the simulation, following this tutorial. Opening four separate terminal tabs, I launched these executables, in order.
- First terminal:
cd sitl/ardupilot-mega/Tools/autotest
./fg_plane_view.sh - Second:
cd sitl
./ArduPlane.elf - Third:
cd sitl/MAVProxy
./mavproxy.py --master tcp:127.0.0.1:5760 --sitl 127.0.0.1:5501 - Fourth:
cd sitl/ardupilot-mega/Tools/autotest/jsbsim
./runsim.py --home=-35.362938,149.165085,584,270 --script=jsbsim/rascal_test.xml --fgout=127.0.0.1:5503
Note that if you execute "./fg_plane_view.sh" last, then FlightGear gets stuck at loading scenery.
This is where I ran into problems. The simulation is not moving. In addition, I discovered that the MAVProxy output is too clean -- it has only ASCII text, no binary MAVLink data. The expected output is described here.
What am I missing?
Edit: It seems that things are working. If I type "auto" into the MAVProxy, as Daniel suggested, the plane starts to fly (and crashes into ground in a minute or two). Still, I see no binary data in MAVProxy output, but this may be a feature.
Hi Rasmus,
Thanks for your Tutorial, Are you still supporting SITL ? I am referring to this tutorial SITL ArduPlane and having some issues with connecting it to X-Plane.
Hi Anand,
Unfortunalely, I am not currently working on flying systems anymore and because of that I do not have the time to keep up to speed on either SITL or Ardupilot in general.
Thanks Rasmus for your reply. Any other discussion you remembered, where SITL is in active discussion now ? I was working towards my Masters research and your thread helped me a lot in getting SITL started but I was hoping to get some more help from the forum.
I do not keep an eye on any SITL discussions other than this. Are the official instructions not working? Check out
http://plane.ardupilot.com/wiki/common-sitl-software-in-the-loop-si...
and
http://plane.ardupilot.com/wiki/common-simulation/
I faced lot of errors while setting up and I got it working once (and Thank god I saved it to a harddrive with working SITL setup, which I couldn't setup on again due to JSBSim path error, anyway it's working now) with this tutorial
http://dev.ardupilot.com/wiki/setting-up-sitl-on-windows/
But I wanted to learn more about running custom missions, adding your custom way-point files etc and also I wanted to know is X-Plane good to go with this SITL setup or Flight gear is preferred as I saw a lot of FG fdm mentioned in the code.
It seems like you have the perfect opportunity to give back to the community by finding out these answers and writing a tutorial or two.
X-Plane vs Flightgear is probably a never-ending discussion where no one is right or wrong, but if you want to know something as specific as adding custom way-point files, then if documentation is lacking, your best source of information might be the source code. This is, in my opinion, the best thing about open source software. If you were facing a proprietary software with lacking or out-of-date documentation, you would have a much harder time.
Thanks Rasmus,
I am still working on running some simulations with study wind effects.
I got to enter my custom way-points and add winds but still working on connecting it to FlightGear or XPLane.
Hi all,
I’m new to this forum, and just starting out with ArduPilot and UAVs, and I’m also pretty new to using Linux so please forgive me if I’m asking obvious questions.
I’ve been trying to get SITL running on a Linux VM for about a week now. I’ve worked my way through most of the tutorials on setting up SITL but I don’t seem to be having much luck, however I have made the most progress with this one :)
I’m getting to the final step of this tutorial and encountering an error running runsim.py, I’ve included the steps I’ve taken below.
If anyone could offer up any suggestions as to what I’m doing wrong it would be greatly appreciated.
Thanks in advance!
I’m running Ubuntu 12.04 LTS in VMWare Fusion 6 and this is the installation procedure I have followed so far:
A1. Open a terminal console window.
A2. Make a new folder for simulation software and enter the directory:
cd ~/
mkdir sitl
cd sitl
A3. Install prerequisites, if missing:
sudo apt-get install git python-serial g++ autoconf libtool automake gawk libexpat1 libexpat1-dev
A4. Download MAVProxy, mavlink, JSBSim and APM:
git clone https://code.google.com/p/ardupilot-mega/git clone git://github.com/diydrones/ardupilot.git
A5. Build and install JSBSim:
cd jsbsim
./autogen.sh
make
sudo make install
cd ..
A6. Build ArduPlane and ArduCopter binaries and copy them from temporary folder:
cd ../..
cd ../..
cp /tmp/ArduCopter.build/ArduPlane.elf .cd ~/sitl/adrupilot/ArduPlane
make configure
make sitl
cd ~/sitl
A7. Install flightgear:
B1. First terminal:
./fg_plane_view.sh
B2. Second:
cd sitl
./ArduPlane.elf
B3. Third:
cd sitl/MAVProxy
Uncomment line 17 of mavproxy.py (to “allow running without installing”)
Copy entire contents of mavlink folder into MAVProxy folder (before I did this there was an error of the mavproxy.py script not fining a file used in line 2165)
B4. Fourth:
Reading comments about JSBSim not installing it's binaries in the system folders when I ran "make install", I added the following folder to the $PATH variable: "~/sitl/jsbsim/src".
PATH=~/sitl/jsbsim/src:$PATH
export PATH
cd sitl/ardupilot/Tools/autotest/jsbsim
This last step produces the following error:
jamiepaton@ubuntu:~/sitl/ardupilot/Tools/autotest/jsbsim$ ./runsim.py --home=-35.362938,149.165085,584,270 --script=jsbsim/rascal_test.xml --fgout=127.0.0.1:5503
Traceback (most recent call last):
File "./runsim.py", line 10, in <module>
from pymavlink import fgFDM
ImportError: No module named pymavlink
I have tried adding the following lines (which I found from another tutorial somewhere too) to the .bashrc file in my home directory, and then retrying step B4.
export PATH=$PATH:$HOME/ardupilot/Tools/autotest
export PATH=$PATH:$HOME/MAVProxy
export PATH=$PATH:$HOME/mavlink/pymavlink/examples
export PATH=$PATH:$HOME/jsbsim/src
export PATH=/usr/lib/ccache:$PATH
And then reloaded the PATH:
. ~/.bashrc
But this didn't seem to make any change to the error.
So if anyone has any suggestions I'd appreciate it :)
I have pulled git yesterday and built ArduPlane for SITL. Followed instructions at http://dev.ardupilot.com/software-in-the-loop-sitl/ and it all started up like a charm in my VirtualBox guest machine. Can even connect with MP from my Windows host (to 5762).
BUT - the plane is rollng from side to side, is pitching up and down both about 45 degrees, there is a "bad gyro health" message and there is no GPS fix. This was after the param load step at the bottom of the manual.
Anyone? Did I miss something?
I am trying to run the SITL simulation and I have been following the tutorials till this step:
>./runsim.py xxx
it shows error messages:
import util, fgFDM, atexit, fdpexpect
ImportError: No module named fgFDM
I have installed Flightgear by doing: sudo apt-get install flightgear. So now I am really confused: where can I get the fgFDM module?
ps: I have done this already:
PATH=~/AutoPilot/jsbsim-master/src:$PATH
export PATH
