I connected everything in the right way, I think.
INPUT1 are the ailerons, INPUT2 is the elevator, INPUT4 is the rudder. The servos are on the same numbers on the OUTPUT side of course.
INPUT3 is the ESC/Throttle and INPUT8 is an AUX-Channel to switch the modes.
If I connect the ESC to the APM it will not initialize. I replaced the ESC with a servo but no movement. All other servos move in manual, RTH and Stabilite mode. (should they move if move the sticks manually in non-manual mode???)
If I connect the servo or the ESC directly on CH3 on the receiver, it works.
I changed the parms THR_MIN to 10 and THR_SUPP_MAN from 0 to 1. No change.
In the radio calibration the throttle channel is working.
Any ideas?
Bye & Thanks!
Manuel
Ok it have something to do with the power.
The ESC will not initialize if I only use the power from the main battery (connected to the power module and the ESC).
If I connect a 4.8V source first on a free INPUT channel, wait 5sec and then plugin the main battery the ESC will initialize and work as aspected...
Let's figure out how to deal with this... Maybe another ESC will work better...
