ArduCopter-3.0.1 released!
Warning #2: GPS glitches can cause sudden and aggressive position changes while in loiter mode.  You may wish to reduce the Loiter PID P to 0.5 (from 1.0) to reduce aggressiveness (see image below of where this gain can be found in mission planner).
Warning #4: loiter turns does not maintain altitude.  This bug will be fixed in AC-3.0.2.
  • Safety improvements:
How to upgrade:
2. Click on the MissionPlanner's Hardware, Install Firmware screen.  The version numbers should appear as "ArduCopter-3.0.1", then click the appropriate frame icon and it should upgrade as per usual.
3. Reduce the Loiter and Alt Hold PIDs if you have modified them from the defaults.  The modified PID values for the 3DR frame can be seen in the image below.
3691038784?profile=original
4. Although not directly related to this release, if you purchased an APM prior to March of 2013, update your PPM encoder to the latest firmware (instructions here).
Special Thanks to MarcoDaveC and the large number of testers on the pre-release thread who put their copters at risk during the extended testing period.  Some of their videos can be found hereherehereherehere and here.  Thanks also to MichaelO for the MP changes required for this release.
  • please tell us why roll back ?
  • T3
    Congratulations to the development team, on a job well done!  Unfortunately I won't be able to test the new code for a few weeks, I'm vacationing in Brazil and my wife would not let me bring a copter with me. ;-(
  • Randy,
    I test flew my F450 quad just the other day. It was a super calm weather just after a heavy rain. I wanted to see the 3 modes (acro, stab. and loiter) when it wasn't windy out there.
    Acro and stab. modes did great. As soon as I switched to Loiter (I had a GPS lock), quad started climbing (not at a fast rate). I thought it would be the throttle_mid parameter issue. I lowered the throttle but it didn't stop the climb. I then turned it back to stab. I realized I didn't have a control. I panicked; switched to acro; still didn't have anything. No control what so ever. The quad was climbing at a steady rate. It was about 20 meters or so. I turned the Tx OFF; hoping that it would RTL land. It didn't do anything. I turned the radio back ON. Right at that second, all motors stopped in mid-air and the quad started to fall. With the fear of losing the entire platform, I didn't do anything and let it fall all the way down. Just about it hit the ground (grass surface), I attempted to fire up the motors to reduce the impact. Motors responded and slowed down the descent rate but it still hit the grass surface and flipped. Luckily no damage. I didn't even break the props.
    I tested the quad after that and everything seemed to be working fine. I didn't want to fly it but all controls were functioning ok. I downloaded the flash log; checked it for a while. I can't find anything. Or let's say I don't know what to look for exactly.
    Do you think you could take a quick look at it and let me know what happened?
    I test flew this quad a few times with same conditions and it was flying okay. I know my compass interference is very and I need to work on it but I doubt it has anything to do with what happened here.
    Would very much appreciated if you could take a look at it. I do not have telemetry; so no tlog...
    I want to know what caused the loss of control and what caused all motors to stop.
    Thanks...
    2013-07-12 20-19 1.log
  • I have found 2 conditions that will cause motors startup and tip overs on the ground: 0 altitude in a mission "takeoff" and "circle" mode mistakenly switched on while at 0 altitude..
    The team has done a fantastic job of protecting us from pilot planning errors but these 2 have bitten me recently.
    Is it possible to block arming if takeoff is at 0 alt and circle mode inadvertently started while on the ground?
    This latest version 3.01 is just fantastic.. Thanks
  • hi Randy
    what options used for official hex compilations?
    i tried to compile git code for quaid but my hex file size was large
    #define DMP_ENABLED ENABLED  in official hex?
  • Trying to get my head around the fail safe setup here and after half a day of lots of reading I think I am making headway.
    I have a Futaba 10CAG and using an FrSkye TFR8 receiver. Ive read that the TFR8 has a fail safe feature as well and they advise to disable FS in the Futaba TX if using this RXs fail safe so I disabled that in the TX. Thats all Ive done so far. I'm not sure if the FS on the TFR8 is on or off yet.
    But when I turn off the TX is see in MP the throttle drops to 900. I'm not sure if this is from the RX setting this or from the APM2.5 boards encoder. (updated to the latest fw version)
    My question is, is this sufficient enough for the FS to work?  Is the setting of 900 from the APM or the RX and how can I check this and is it to low at 900?
    Just with the USB cable connected and the APM armed, when I turn off the TX it disarms the APM. There is no GPS lock as this is indoors. Will this fail safe work without GPS lock if just flying in stabilize mode?
  • Congratulation developers,
    A job well done. Thank you very much for your time, effort and support.
    I had a go at 3.0.1rc2 at it worked great. Looking at the log I saw roll/pitch following rollin/pitchin with minor oscillations in STABILIZE. Reducing RATE_RLL_P and RATE_PIT_P got rid of the oscillations. After replacing the pink foam in that came with the APM case with black thicker foam I believe my random changes in altitude also went. ALT_HOLD, LOITER (now without wobble) and CIRCLE mode worked fine so I was confident enough for an AUTO mission. AUTO also worked fine but left me with a question on how to put in a mission command that does the same as CIRCLE mode. I tried LOITER_TURNS with 1 turn and a 0 in the altitude field. Reaching this command after aq waypoint in 60ft altitude the copter descended.I aborted 5 ft off the ground. Do I have to put in an altitude in the altitude field? I was under the impression 0 equals to current altitude.
    Can somebody please advise on how to use LOITER_TURNS and on how ROI works?
    Thanks,
    Michael
  • With the 3DR IV Sensor power module, does this supply enough power to the APM2.5 board so that the out put pins on A10 and A11 are sufficiently able to power the servos for the camera gimbal? Or do we still need to use a separate ubec to avoid brown outs?  I am using two small analog 9g servos.
    Also is this comment still relevant for the setting up the 3DR IV Sensor Power module?
    " You need to measure the voltage from the Power Module's regulator after the APM's diode and fuse, an easily accessible point to measure this is the fuse's lead highlighted in the image above. Type your measured voltage into the field labeled  1. APM Input voltage".
    This area grays out and becomes not editable when selecting this power module so I assume this is not needed now?
    Lastly , I'm a bit confused between Throttle Accel and Throttle Rate and which one to set to get a firm hover. My hover tends to wanders up and down a bit and I have to constantly adjust the throttle and its difficult to find a throttle position where it maintains a stable hover position. . Note this is during flying indoors with no sonar and no GPS and only in stabilize mode. Ive not tried it outdoor yet. (broken leg has stopped play)
  • Excellent work on 3.0.1. It is amazing!  I use SimonK ESCs and I'm still getting some twitch and wandering in Loiter. It is significantly better than 3.0r1
    I'm new to ArduCopter (experience with ArduPlane). I'm not sure if it is a SimonK ESC issue or a configuration issue. I have done some RATE D and P tuning based on the instructions from DaveC.
    Here is my set up:
    F450 frame
    APM 2.5
    ArduCopter 3.0.1
    SimonK ESC 30A
    RCTimer 2830 - 1000KV motors
    Here are my PID settings. I did reduce Loiter PID P per warning #2.
    3692772674?profile=original
    Log files attached below.
    Any feedback is appreciated.
    3.0.1_simonK_loiter_text.zip
  • I have a weird problem: copter in loiter mode slowly climbs up. Barometer and GPS alts seems reflect the actual altitude, sonar is not even connected and is always 0m. At the plot below at 20 I switched into stabilize mode and brought the copter down a bit, then switched back to loiter.
    This is the original 3DR APM2.5 with F450 frame.
    3692772515?profile=original
