ArduCopter-3.0.1 released!
Warning #2: GPS glitches can cause sudden and aggressive position changes while in loiter mode.  You may wish to reduce the Loiter PID P to 0.5 (from 1.0) to reduce aggressiveness (see image below of where this gain can be found in mission planner).
Warning #4: loiter turns does not maintain altitude.  This bug will be fixed in AC-3.0.2.
  • Safety improvements:
How to upgrade:
2. Click on the MissionPlanner's Hardware, Install Firmware screen.  The version numbers should appear as "ArduCopter-3.0.1", then click the appropriate frame icon and it should upgrade as per usual.
3. Reduce the Loiter and Alt Hold PIDs if you have modified them from the defaults.  The modified PID values for the 3DR frame can be seen in the image below.
3691038784?profile=original
4. Although not directly related to this release, if you purchased an APM prior to March of 2013, update your PPM encoder to the latest firmware (instructions here).
Special Thanks to MarcoDaveC and the large number of testers on the pre-release thread who put their copters at risk during the extended testing period.  Some of their videos can be found hereherehereherehere and here.  Thanks also to MichaelO for the MP changes required for this release.
  • Does anyone know how to alter the radio input code so I can switch channel 1 for channel 2 as im using a jr tx with ppm.
    Im updating from 2.9.0 to 3.0.1. With 2.9.0 I altered the code in the radio.pde as Randy (see below) suggested to switch channel 1 and 2 around for use with jr tx with frsky ppm. This worked fine in 2.9 but doesnt seem to work in 3. I assume its something to do with RC HAL something or other but I dont really know. And Ideas on what I can alter to make it work this time?
    Cheers
    Alex
    Hi there.  I didn't see this thread and really wasn't aware of the issue.
    The hacky solution is to modify radio.pde's read_radio() function.  This is where it copies the input from the APM_RC object to the internal "servo" objects that we use from then on.  So it looks like you could set your transmitter to mode 2 and then only roll and pitch are reversed.  You could then change the read_radio() fuction to be this.  In fact it's just the two lines in bold that have been modified slightly (CH1 and CH2 have been switched around).  If someone knows how to upload the code with Arduino perhaps they could try to make these small changes and see if it works?  Then we can make a more permanent fix for 2.9.2.
    #define RADIO_FS_TIMEOUT_MS 2000       // 2 seconds static void read_radio() {     if (APM_RC.GetState() == 1) {         ap_system.new_radio_frame = true;
      g.rc_1.set_pwm(APM_RC.InputCh(CH_2));          // reversed for JR transmitter                      g.rc_2.set_pwm(APM_RC.InputCh(CH_1));          // reversed for JR transmitter
    set_throttle_and_failsafe(APM_RC.InputCh(CH_3));
     g.rc_4.set_pwm(APM_RC.InputCh(CH_4));
    g.rc_5.set_pwm(APM_RC.InputCh(CH_5));
    g.rc_6.set_pwm(APM_RC.InputCh(CH_6));
    g.rc_7.set_pwm(APM_RC.InputCh(CH_7));
    g.rc_8.set_pwm(APM_RC.InputCh(CH_8));
    #if FRAME_CONFIG != HELI_FRAME         // limit our input to 800 so we can still pitch and roll         g.rc_3.control_in = min(g.rc_3.control_in, MAXIMUM_THROTTLE); #endif     }else{         // turn on throttle failsafe if no update from ppm encoder for 2 seconds         uint32_t last_rc_update = APM_RC.get_last_update();         if ((millis() - last_rc_update >= RADIO_FS_TIMEOUT_MS) && g.failsafe_throttle && motors.armed() && !ap.failsafe) {             Log_Write_Error(ERROR_SUBSYSTEM_RADIO, ERROR_CODE_RADIO_LATE_FRAME);             set_failsafe(true);         }     } }
    Remember if you're uploading using arduino to an APM 2.x you will need to remove the two "//" from the front of line 5 of APM_Config.h so that it looks like this:
    #define CONFIG_APM_HARDWARE APM_HARDWARE_APM2
  • I have one question regarding compass live calibration.
    Is it recommended that when you do the live calibration to power all the external electrical equipment during the process. This includes than all external lights, gimbal, FPV equipment and so on. I would imagine that would give better calibration but since my knowledge on this matter is none I wanted to have your opinion.
    Also does it have any affect if you do the calibration indoors or outdoors?
    Thanks!
  • Hi Randy,
    i want to replace the barometer of APM with a new one.
    http://www.raspberrer.com/resistenze-termistori-diodi-ldr/375-ms561...
    is it possible?
    theoretically should be replaced with the new i2c address in the source code and recompile the project
    right?
    thx
  • help me please, my board was broke
    it start when i'm release the gps when it's on and then the red and blue led doesn't blinking anymore
    any conclusion ?
  • Nice work guys...
  • Randy
    I would be grateful if you could take a look at this log file and confirm my interpretation is correct.
    Is the autopilot switch modes very quickly. I was wondering is it an issue with the transmitter program, but I can’t replicate on the ground.
    Also what could be the cause of the spike in the DHOP? this is not bad today but yesterday was very bad.
    David Ardis
    2013-08-25 16-30 3.log
  • Hi Reuben,
    i checked your logs again and you are right. It seems that i checked the wrong file. It wasn't yours.
    On the logfile from you i couldn't see a voltage. Do you use the 3dr Power Module ?
    In the picture attached there are all motors and the Baro Alt. As i can see the Baro Alt suddenly stopped. Take a look to this Information
    Log Wiki
    On the Chapter Power Problems, the Graph looks like yours. So possible you have an Brown Out.
    But as i said, im a beginner in reading and analyzing Logfiles. Perhaps anyone can check it and give some Help to understand your Crash.
    Christian
    any conclusion ?
  • Hello,
    first, this firmware flies great. Thaks to the devs.
    But I discovered a problem. If I trigger Failsafe RTL the copter is spinning around the yaw-axis?
    I have a Y6, did all callibrations and also the compassmot and have low vibrations. I did the compassmot 3 times. First it was about 110%, second time it was about 160% and the third time it was about 60%. All conditions between these were the same. Nevertheless Loiter is quite good.
    Another question, is it possible to reduce some wobble if I change the IMU update rate from 20Hz to 42Hz?
    2013-08-23 09-41 13.log
  • Hello Reuben,
    my english isn't so good and i'm just beginning to understand the log Files.
    I've attached a picture from your logfile at which you can see the Battery Voltage and the Altitude.
    Do you use an 4s Lipo for your hexa ? In this case i think you use an empty Lipo.
    At the start of the Log your Lipo has an amount of 14,9 V (3.7 per Cell on 4s).
    Perhaps i'm completly wrong but i think that u started with an empty Lipo.
    Christian
DIY Robocars via Twitter
RT @DanielChiaJH: @a1k0n @diyrobocars @circuitlaunch And here's the final showdown! Video courtesy of @chr1sa I think I was a little faste…
3 hours ago
RT @DanielChiaJH: @a1k0n @armand_dpl @SmallpixelCar @diyrobocars @circuitlaunch I use @foxglovedev Foxglove Studio for my visualization nee…
3 hours ago
3 hours ago
RT @a1k0n: @DanielChiaJH @diyrobocars @circuitlaunch Here's my car's view of that race. About 8.4 second lap times for laps 2 and 3... both…
Monday
RT @DanielChiaJH: Great racing against @a1k0n today at @diyrobocars! Pretty cool to both break sun-9s at the track today I think I got very…
Sunday
Broadcasting the @circuitlaunch race live now at https://m.twitch.tv/diyrobocars Races begin around 2:00pm PT
Saturday
RT @a1k0n: ran a huge number of hyperparameter tuning experiments yesterday; now I can train a new policy, far with better quality, in 15 m…
Saturday
RT @a1k0n: Did I get rid of hand-tuned parameters? Yes. Am I still hand-tuning more parameters? Also yes. I have a few knobs to address the…
Sep 26
RT @a1k0n: I'm not going to spoil it, but (after charging the battery) this works way better than it has any right to. The car is now faste…
Sep 26
Sep 26
Sep 24
Sep 24
Sep 24
Sep 23
Sep 22
Sep 11
