ArduCopter-3.0.1 released!
Warning #2: GPS glitches can cause sudden and aggressive position changes while in loiter mode.  You may wish to reduce the Loiter PID P to 0.5 (from 1.0) to reduce aggressiveness (see image below of where this gain can be found in mission planner).
Warning #4: loiter turns does not maintain altitude.  This bug will be fixed in AC-3.0.2.
  • Safety improvements:
How to upgrade:
2. Click on the MissionPlanner's Hardware, Install Firmware screen.  The version numbers should appear as "ArduCopter-3.0.1", then click the appropriate frame icon and it should upgrade as per usual.
3. Reduce the Loiter and Alt Hold PIDs if you have modified them from the defaults.  The modified PID values for the 3DR frame can be seen in the image below.
3691038784?profile=original
4. Although not directly related to this release, if you purchased an APM prior to March of 2013, update your PPM encoder to the latest firmware (instructions here).
Special Thanks to Marco, DaveC and the large number of testers on the pre-release thread who put their copters at risk during the extended testing period.  Some of their videos can be found here, here, here, here, here and here.  Thanks also to MichaelO for the MP changes required for this release.
    For those interested in Beta testing the AC3-1 release, release candidate #4 is now available in the Mission Planner's "Beta firmwares" link.  Improvements over 3.1-rc3
    1) Performance improvements to resolve APM alt hold and telemetry issues especially during Loiter:
         a) SPI bus speed increased from 500khz to 8Mhz
         b) Telemetry buffer increased to 512bytes
         c) broke up medium and slow loops into individual scheduled tasks and increased priority of alt hold tasks
    2) AutoTune enabled by default
    3) Bug fix for Pixhawk USB connection
    4) GPS Glitch improvements:
           a) added GPS glitch check to arming check
           b) parameters for vehicle max acceleration (GPSGLITCH_ACCEL) and always-ok radius (GPSGLICH_RADIUS)
    All feedback welcome!
  • Hi
    I just fly Y6 on this motor setup by ArduCopter3.1 rc4.
    3692855046?profile=original
    The loiter and Alt_hold are just perfect in calm weather.
    I do not know this significant improvement of stability comes from whether the effect of external compass or rc4.
    But this is totally different copter.
    Thank you dev. team.
  • I nearly crashed.
    check the status of solar storms
    M-CLASS FLARE, EARTH-DIRECTED CME: October 13th began with an explosion on the sun. At 00:43 UT, sunspot AR1865 erupted, producing an M1-class solar flare and an Earth-directed CME. NASA's Solar Dynamics Observatory captured the explosion's flash of extreme UV radiation:
    Soon after the flare, the Solar and Heliospheric Observatory recorded a faint CME emerging from the blast site: movie. Based on the approximate speed of the expanding cloud, between 600 km/s and 800 km/s, it will probably reach Earth on Oct. 15-16. Polar geomagnetic storms are possible when the CME arrives. Aurora alerts: text, voice.
    3692854586?profile=original3692854604?profile=original
    2013-10-13 18-31 3.log
    2013-10-13 18-24 1.log
  • Heading hold In Loiter.
    As we all know, the position in loiter is fixed in space and the copter strongly attempts to get back to its original position when disturbed. However I have noticed that if its heading is disturbed there is no tendency to return to the original heading. There is a weak attempt to resist the yaw but then it is quite content to stay on the new heading. This may seem like an ‘I’ term function but I have tried adjusting many things to improve it but cant.
    My gimbal, like most people’s is just 2 axis so I am relying on the copter to maintain an accurate heading while filming. The Loiter position holding is spectacularly good but the heading can get knocked off on a windy day.
    Im still on the last ‘full’ release. 3.0.1?
    Any ideas?
  • I made a test today of AC 3.1-rc3. Alt Hold seems to be improved from 3.0.1 with a better feeling in Throttle adjustment. I just changed THROTTLE_IN_DEADBAND to 50 and PILOT_VELZ_MAX to 500
    I also tried the AUTO_TUNE, the result with my TBS (Quad V Frame) is not fine. After tuning, when I want to turn my copter, instead of having one side going down (with pitch down, yaw and roll right or left), only a corner of my copter is going down. For example (http://copter.ardupilot.com/wiki/motor-setup/) M1 is going down, M2 is going up, M3 and M4 stay level, so I can't fly.
    I also tried to "pause" Tuning with CH8 in middle position, but when doing that, it seems my copter restart tuning from the beginning.
    One last thing, I also reduce DISARM_DELAY, to cut my motors quicker.
    David
  • Is it ok if the quad moves during compassmot?
    Development on the APM 2.X is not stopping!!!
    I would like to make it clear that the APM development is not stopping. In Randy's hast to communicate to the community the limitations the Dev's are facing on the APM platform and Robert's discovery of the processor issues with mount, some people have the impression to some that 3.2 will be the last APM release, or that the APM isn't up to the task. This isn't the case.
    Some facts:
    1. New features like scripting and automatic path planning using stored maps will not be added to the APM because they require cpu power the APM simply doesn't have.
    2. Some existing features may be removed or only available with a custom compile because no body uses them or they are outdated. Things like toy mode, position hold (loiter with manual throttle), and mount.
    3. New features like auto tune or spline navigation may be added in the release or made available as a compile time option depending on their requirements and significance.
    4. Improvements to the basic controller design will continue to be made as they generally will reduce the code size rather than increase it. (Randy and I are working on this now)
    5. Bugs and problems will continue to be fixed. (the only problem with this is there aren't many of them left!)
    6. Tridge and Randy have implemented a large number of CPU performance improvements that have given the APM significantly more processor headroom for low priority tasks.
    7. As we update the code to make the most of the PX4 hardware, many of these changes are also improving the performance of the APM hardware!
    8. For the foreseeable future there won't be separate code base for the APM and PX4. This means all the basic bug fixes we implement on the PX4 will also be fixed on the APM.
    In short, the Dev's are still working on the APM hardware with the intention of polishing it to an unarguable thing of absolute beauty and reliability. This is in term acting as a fantastic spring board for the PX4 based features that are sure to come with the added processing capability and memory.
    Future releases of the APM, post 3.2 (or 3.3) will begin to have absolutely no new features or major changes, just reliability and efficiency improvements. We are so close to this now and this is why people have suggested that 3.2 will be the last major release for the APM's.
    The APM is a fully featured autopilot and great control hardware platform and I believe it will make controllers like the Wookong look silly for a long time. (It is also excellent for ACRO and FPV)
    I personally think this is a very proud time for the APM's :)
  • One question...since i will be ordering Pixhawk (APM 2 is too old,its time to move on...)and other components,
    should i order PX4FLOW as well or it is to early to have any real use of that?
  • T3
    Dear all,
    I have some fail save questions:
    I have set Low_Volt (what is now called FS_Batt_Voltage) to 14V. At 13.7V Land mode was triggered but the copter remained in some Loiter state. Where can I define "what action to take". I am preferring RTL. The 13.7V might come from a mixing of decimal separators in the German version - but I am not sure.
    For the Fence Action one can select "RTL or Land". Can these be specified somewhere?
    Thanks in advance,
    Thorsten
    PS: 3.1rc2 worked flawless on my long endurance hexa (link 1, link 2) in Auto missions with CAM_TRIGG_DIST, Loiter and Stabilize. Now I am in the process of switching to rc3.
    Randy,
    You say that is APM 2.5/2.6 is near its CPU limit and almost no space to grow new functions. Does that mean that Arducopter-3.2 (example) can have new functions that will work on Pixhawk but not on APM? Or you will hold back the development to accomodate APM CPU? I mean, when are you step up to pixhawk on a firmware?
