ArduCopter-3.0.1 released!
Warning #2: GPS glitches can cause sudden and aggressive position changes while in loiter mode.  You may wish to reduce the Loiter PID P to 0.5 (from 1.0) to reduce aggressiveness (see image below of where this gain can be found in mission planner).
Warning #4: loiter turns does not maintain altitude.  This bug will be fixed in AC-3.0.2.
  • Safety improvements:
How to upgrade:
2. Click on the MissionPlanner's Hardware, Install Firmware screen.  The version numbers should appear as "ArduCopter-3.0.1", then click the appropriate frame icon and it should upgrade as per usual.
3. Reduce the Loiter and Alt Hold PIDs if you have modified them from the defaults.  The modified PID values for the 3DR frame can be seen in the image below.
3691038784?profile=original
4. Although not directly related to this release, if you purchased an APM prior to March of 2013, update your PPM encoder to the latest firmware (instructions here).
Special Thanks to MarcoDaveC and the large number of testers on the pre-release thread who put their copters at risk during the extended testing period.  Some of their videos can be found hereherehereherehere and here.  Thanks also to MichaelO for the MP changes required for this release.
  • Has any one used the Vibration control mount that some one posted a link to a bit back? how much height is needed to use it? how does it work? i have way too much Z vibration on my Drones. can some one repost the link to that Mount? thanks in advance
  • Hi Randy,
    RC8 was great!  My only issue is that I cannot tune the altitude mode to be steady at mid stick.  Following that, I attempted to Auto Tune  at 40ft (safe height for recovery to stabilize mode) and the quad will either gradually climb or loose altitude to the point where immediate input is required.  I have attached four logs.  Your suggestions would be greatly appreciated.  By the way, I have Velcro strapped around the APM.  Would that effect my Barometer?  And I've just flashed 3.1..........:)
    Wavev
    2013-12-15 12-06 1.log
    2013-12-15 12-11 2.log
    2013-12-15 12-12 3.log
  • APM:Copter 3.1 is released! Flashing time :D
  • Hello!
    I had a crash yesterday with 3.1RC7
    https://www.youtube.com/watch?v=xwA8ik8yuVo
    I was flying normally when I fliped and crash :(
    I have no idea about what could happen.
    I attached the log.
    Regards
    2013-12-14 13-53.log
    Ok AC3.1 is released!
    Thanks to those who submitted videos, in the end I had a hard time putting it together into a sexy release video so Marco was kind enough to create one. I've added links to your videos at the bottom of the release discussion and please PM me if I've missed one that you'd like included.
    Thanks again for all the testing you all did, putting your copters at risk in the process.  I'm sure it's contributed massively to making it a good release.
    By the way, we're going to push out AC3.2-dev later today.  This release candidate is a special release mostly for the people who will be receiving the Pixhawk 2.4 boards in the next couple of weeks and has "dual sensor support" including fail-over to the backup accels, gyros and compass.  The Pixhawk hardware people want this available so they can do more evaluation of the ST accels/gyros vs the MPU6k.
  • Hello all,
    My BarAlt seems very noisy to me. Is this something to do with 3.1-rc7 or is that I am getting too much prop wash? I also noticed that the foam (that protects the Barometer) inside my 1 year APM 2.5  is not as flexible and a little flattened as when it was new. I moved the AMP 2.5 further to the back of my Hex recently instead of it being centered. My flight was fine and Alt-hold was fine. But I am still concerned. What do you think?
    Thanks.
  • Hi Randy & Developers around the world,
    Can we work now for battery efficiency? I know some of you are skeptical, but I believe there are a lot of brilliant minds here!
  • Some smooth cinematic video on 3.1 rc7
  • Hello. I have some strange alt behaviour on my APM2.5.2 from rctimer. It drifts for 5-10 meters when being turned upside down or on it's side. Same thing on both 3.0.1 and 3.1rc8. Also, when I do terminal>test>baro, the raw readings are steady and good, so I suppose it isn't the barometer fault (anyway it is well shielded and was treated with care). Here is a video
  • Hi all, I would like to know about the accelerometer calibration, always calibrated as shown in this video:
    http://vimeo.com/56224615
    but mnya today were pelted with tomatoes explaining that it is relevant to 2.9 versions and new from 3.... we should not just put exactly as put by the level of construction, where the truth can you do without the level
    Ps: my flies beetle perfectly and....
DIY Robocars via Twitter
Sunday
May 14
May 13
May 13
May 11
May 8
May 8
RT @SmallpixelCar: Test my car. RTK GPS worked great. Thanks @emlid for their support. https://t.co/EkQ6qmjmWR
May 8
DIY Drones via Twitter
RT @chr1sa: @kane That's @diydrones circa 2009. Still have a box of those Canon cameras that we used to strap into planes, just like this.…
May 3
RT @chr1sa: Our next @diyrobocars race is going to be outside at a real RC racetrack in Fremont on May 28. Fully autonomous racing, head-to…
Apr 30
RT @f1tenth: Our Spring 2022 F1TENTH course @PennEngineers is coming to an end with a head-to-head race as a big finale. So proud of our st…
Apr 26
RT @DanielChiaJH: I wrote a thing! Throughout the development of my @diyrobocars car I've been using @foxglovedev Studio to visualize and d…
Apr 23
RT @SmallpixelCar: My new car for high speed. Low body, everything ( @NVIDIAEmbedded Jetson Xavier NX, @emlid RTK GPS, IMC) under the deck…
Apr 23
Apr 21
RT @f1tenth: F1TENTH Race training setup @PennEngineers for our upcoming ICRA2022 @ieee_ras_icra competition. @OpenRoboticsOrg @IndyAChalle…
Apr 21
RT @fatcatFABLAB: Proud to be hosting a restarted DIY Robocars NYC Meetup April 26. Come by if you want to talk about and race self-driving…
Apr 17
