ArduCopter-3.2 beta testing
Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
            • If you want to refer to 3.2-rc1, the link I provided is the right one. The other more recent build weren't released as such and are "work in progress", not guaranted to work
              • 3.2-rc2 is now strait from the beta download. Though don't know were "motor sync test" disappear?
                Will test the rc2 shortly.
                  Henri,
                      that's actually AC 3.1.5-rc2 in the beta firmwares area so it's quite a step back.  testing is appreciated but none of the AC3.2 features will be there.
                  • Hi Randy,
                    When will be AC3.2-rc2 available?
          Henri, Oliver,
               It'll still be a couple of days I think.  There's a crash report on AC3.1.5-rc1 that Jonathan will be investigating and once we're sure it's unrelated to the release we can pull out AC3.1.5 and put back AC3.2-rc2.
          • Thanks Randy, sorry to be a pest but it's really helpful to have some even rough timeline so as to be able to make plans for limited free time...
  • I have been using 3.2-rc1 on my Pixhawk as it was supporting sbus. I have just tried to reflash it and the only beta firmware I can find is V3.1.5-rc2 which doesn't work with my Rx on Sbus. Where can I get the previous V3.2-rc1? Thanks.
  • Is there any info when we can expect the 3.2 rc2 in MP?
  • Thanks team,
    My skills and knowledge in all things RC have improved out of sight over the past 2 years since discovering APM and this community.
    Have donated some cash but wish I could contribute more!
    Thank you.
  • I flew another two battery packs out on the APM 2.6 Quad today.
    Did an Auto-tune first before flying the previous days waypoint mission again. Auto tune seems to proceed well, the final values changed a bit but handling afterwards was much like the result of the auto-tune done a few months ago (which was a good tune).
    The waypoint mission flew OK but it still had some slight pitch bumps between waypoints, and the loiter circle seems to be way under size.
    A question. Where is there some notes on the flash logs PM parameters meaning ?
    I noted that there are some 'hits' in INAVErr, NLon and NLoop log charts, particularly when in Auto waypoint mode, if they really mean what I'm guessing...
    Martin
Aug 25
