ArduCopter-3.2 beta testing
Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
    • After flying rc2 for a while I finally gave up and went back to the old firmware. It has a large amount of bugs and needs lots of work. They need to take their time so don't push them.
      • Mike,
        I fly 3.2RC2 on a custom 550 H Quad (pixhawk with EKF on) and a 550 hex (APM).  I have flown mostly, hybrid, Auto, (including Auto with spline), Alt hold, and RTL.
        I have had no issues and find that 3.2 flies better than any earlier code in both the APM and Pixhawk variants.
        Specifically which bugs are you referring to?
      • Hi Mike,
        Sorry to hear this! I am flying 3.2rc2 on a Y6 (pixhawk), a 450 sized quad(pixhawk), and a 250 size quad (APM26). They all fly amazingly - what issues are you having?
        My only problem is the impossibility of downloading logs over mavlink from my APM..
        Best,
        Raph
    • This reply was deleted.
      • I confirm this report in Mission Planner. I try and reinstall the MP in Windows 7 system and Hybrid mode is not there!
        ATTENTION: MISSION PLANNER DEVELOPERS!
        jay
        Everyone is responsible for his actions... ;-)
        Don't try beta versions on big machine until they are released in the final version.
  • has anyone tested it on APM1 boards? I'm going to load it and try it out on my old boards and see how it stacks up.
  • Hi, i´m using Arducopter libraries to make my own firmware to fly my copters, i dont know if its a bug only for the pixhawk, because i was using the optical flow sensor PX4Flow (via i2c ) in the APM and works with Arducopter 3.2 libraries, but now i have the pixhawk but i can´t make communication with the sensor, i used a logic analyzer to see the bus but in the pixhawk i only see the comunication  with  the compass, with apm i don't have problems.
    Could be a problem only for the  Pixhawk i2c libraries or the PX4 HAL in AC 3.2 ?.
  • Well this is certainly not good news for DRONE fliers, http://gizmodo.com/drones-are-now-banned-in-every-national-park-in-... Drones Are Now Banned in Every National Park In America
