ArduCopter-3.2 beta testing
Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
    • I have build the latest version of MinimOSD with the new modes and changed hybrid to poshold
      https://www.dropbox.com/s/dmjuncam0jxhthb/MinimOSD_22.1.hex
      Dropbox - Error
      Dropbox is a free service that lets you bring your photos, docs, and videos anywhere and share them easily. Never email yourself a file again!
      • here is the file
        MinimOSD_22.1.hex
        https://storage.ning.com/topology/rest/1.0/file/get/3702663706?profile=original
  • Hi Randy, Today, I tested AC3.2 RC5 on four different frames, shown below, using APM2.6 (external compass+uBlox 6M GPS, Sonar disabled).
    In all of them, I observed that in loiter mode the quad do it very well, but it goes on gaining altitude. What I need to change in the parameters ?
    3701809288?profile=original
      Vishal,
           Thanks for testing.  It's impossible to know the cause of the climb without a dataflash log, if you have one I'm happy to take a look.  I'd guess it's one of these issues:
               1. vibration
               2. throttle stick held above mid
               3. barometer drift
      • Hi Randy,
        I tried to download the log but in APM, I am not being able to do so as when I try to that in terminal window, APM starts sending MAVLink data only.
          Vishal,
          Yup, that's right.  Please check Warning #3 above including the link to the wiki page.
  • Thanks randy,
    Could I turn off the INAV/EKF check's? or how can I protect myself against a unwanted landing?
    Surely if they are "too Strict" that is just a tuning problem, or am I missing something?
    • Yesterday flew first time with AC3.2rc5 and most everything worked beautiful. Tried a mission with spline waypoints and ROI which worked out great.
      Sometime after the mission I manually invoked RTL and noticed that the yaw didn't point to home neither to the previously defined ROI, but I guess this can be remedied by properly setting back that yaw_behave(?) parameter after the mission which I of course did miss.
      Had a fence breach which worked out correctly invoking RTL, but somewhere at the end of the battery the copter switched to autoland mode. (Showing errors 17-1 and 16-something if I remember correctly).
      Switched back to AH and PH and no harm done but would be great if we could do something to perhaps weaken those too strict inav checks until 3.2 is out. Any recommendations?
        Zidlov,
        Yes, the INAV/EKF checks are too strict.  Try increasing the EKFCHECK_THRESH value.  It's defaulting to 0.6 but try something higher.  I've been doing some more testing today and it may need to be much higher, like 2.0.
        Alternatively you can turn off the check completely by setting the THRESH to zero.
        • OK I set mine to 2.0 and will see if it helps. BTW, in Full Parameter List where it has Range, would be nice to have the range there but also the default value for each item. It would be very helpful to be able to scan down and see where my settings differ from the default, especially since the default sometimes changes from version to version.
