ArduCopter-3.2 beta testing
Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
  • How do I completely reset an APM 2.6 running ArduCopter 3.2-rc10?  My APM is doing crazy things with my quad, and I just want to reset everything to factory.
      The above ways work but the easiest way is to use the MP's Config/Tuning >> Full Parameter List page's "Reset to Default" button.  If this screen isn't visible when connected you may need to go to Config/Tuning >> Planner and check the Advanced checkbox.
      3702522835?profile=original
    • What I do is to update to plane and them arducopter, when you change vehicle I understand that reset all.
      • Thanks guys. I considered doing this, but wasn't sure if it would work. I appreciate the validation!
        • I do like this to update to 3.2 rc10  and works for me
          • Is the horizon in the HUD stable ? Is compass health okay ?, If not then the 3.3V regulator (Package: SOT-23-5) has blown, replace it but if not then in mission planner do contrl+F, there is option to wipe the EEPROM, you can try that and give reset to the APM.
    • One sure fire way to make sure everything is gone is load Plane or Rover on it and then re-load Copter.
  • Hi,
    i did some testing and here are the results after 3 lipos. I did the compassID trick to avoid a new calibration.
    (EKF off)
    Stabilize:OK
    Althold: OK
    Land in Althold: 2x OK(motors shuting down nicely after land), 1x fail(touched ground bit to hard-->motors spin up-->switched to stabilize)
    Loiter:OK
    Poshold:OK, very smooth breaking
    ResetToArmedYaw function missing
    Thanks DevTeam!!
    Pls see one flight completely in PosHold:
  • I have completed multiple auto flights in the last week and all seems to be working very well. one thing I have recently noticed is that sometimes it will yaw to the next waypoint and sometimes it will not. I have verified in the parameter file that it is set to yaw in the direction of the next waypoint, yet sometimes it still does not yaw correctly. Has anyone else experienced this while flying 3.2RC10 on a traditional helicopter?
    I will put a log file together showing this.
    Joe
    • Hi Joe, I have not noticed that myself.
