ArduCopter-3.2 beta testing
Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
      • Yes, I have. I not only lose altitude level. I'm losing all stabilize function
          Alp,
          Definitely need a dataflash log file.
          • Hello Randy,
            About my upper report, please tell me if it's miss use from my part or if my repported issue could be considered as bug.
  • Randy,
    Crash due to bug in GPS failsafe or Land mode or Geo Fence.
    The log attached shows you a flight that I realized in specific conditions:
    Takeoff in a valley where there was not GPS (sats 0).
    => Préarm check prevents arming the drone
    => I deactivated pre-arm check
    I took off in ALT HOLD, and when the drone took height, it acquired the gps, then it moved very quickly at the max lean angle set (30 deg) against a rock wall and smashed it.
    It happens that others like me want to take off from a place where there are no GPS.
    To prevent this behavior to other users, you can ensure to disable following functions if the drone does not have a GPS HDOP GOOD when arming:
    • Geofence
    • GPS FAILSAFE
    • RTL
    Also that LAND works only in inertial mode.
    And other flight modes using GPS as Loiter only work in flight if GPS HDOP GOOD is reached.
    it would be interesting that you explain how GPS GLITCH react when drone take off without gps and when it acquire GPS positions in flight.
    43.BIN
  • Hello
    A small task
    to use our experimental carrier is with pixhawk 3.2 RC12
    http://youtu.be/LcixgRRB4sU
    • Awesome flight test but where's the dog that goes with the leash? Are you planning to use the drone to walk the dog later?  LOL
  • Firstly, Thanks to all of the Developers and Testers out there!!  Great work.
    Today, tested RC12 on  Pixhawk X250 Quad.  AMAZING!  Very happy!
    Everything I checked worked extremely well (as far as I can tell).  I left my MS Surface at home (in the rush to bet the weather) so I couldn't really do any tuning.  Just used defaults with a small change to the climb rate PID.
    Tried both 1300 and 2200 mAh batteries and the extra weight caused a slight increase in the hover throttle % (as expected) but no major down side in performance.
    Flew:
    Stabilize = OK
    AltHold = OK
    PosHold = OK
    Drift = OK
    RTL = OK
    Land = OK
    I have a large MAG offset in the Z axis but this does not seem to harm the performance.  Probably due to the FPV camera being right under the GPS/Compass.
    MAG OFFSETS = X:-27.00, Y:40.00, Z:216.00
    I checked the EKF data and the IMX, IMY, and IMZ innovations & SMX, SMY and SMZ measurements are all in limits.  I think that is the right place to check as I think this should show any errors or inconsistencies in navy calculations.
    Is it OK to leave this?
    PosHold, Alt Hold and Drift  felt rock solid. In stabilise it climbs very well, a bit slower in other modes. Overall, everything worked exceptionally well.
    Thanks for all the hard work done.  Hear is a log if it can be of any use.
    2014-10-13 11-14-10 x250 1300b02.log
  • Randy and All,
       On the Morning, I have test is Auto Spline Waypoint with 3.2-rc12 is very stable and perfect. And, I have show my video @ below.
  • Here is something that happen to me...
    On two different setups, one with genuine pixhawk and the other with a clone.
    Using teeny 3.1 on telemetry port 2 for datalink to Taranis on both setup
    after update from 3.15 to 3.2 RC12 on the genuine Pixhawk every thing is good.
    after update from 3.15 to 3.2 RC12 on the clone, unable to get data, no exchanges between teensy and clone. If revert to 3.15, all is back O.K.
    Thank you for any ideas and support with this
    and...  Keep the good work, it is greatly appreciated.
    Mario
DIY Robocars via Twitter
RT @chr1sa: Just a week to go before our next @DIYRobocars race at @circuitlaunch, complete with famous Brazilian BBQ. It's free, fun for k…
17 hours ago
How to use the new @donkey_car graphical UI to edit driving data for better training https://www.youtube.com/watch?v=J5-zHNeNebQ
Nov 28
RT @SmallpixelCar: Wrote a program to find the light positions at @circuitlaunch. Here is the hypothesis of the light locations updating ba…
Nov 26
RT @SmallpixelCar: Broke my @HokuyoUsa Lidar today. Luckily the non-cone localization, based on @a1k0n LightSLAM idea, works. It will help…
Nov 25
@gclue_akira CC @NVIDIAEmbedded
Nov 23
RT @luxonis: OAK-D PoE Autonomous Vehicle (Courtesy of zonyl in our Discord: https://discord.gg/EPsZHkg9Nx) https://t.co/PNDewvJdrb
Nov 23
RT @f1tenth: It is getting dark and rainy on the F1TENTH racetrack in the @LGSVLSimulator. Testing out the new flood lights for the racetra…
Nov 23
RT @JoeSpeeds: Live Now! Alex of @IndyAChallenge winning @TU_Muenchen team talking about their racing strategy and open source @OpenRobotic…
Nov 20
RT @DAVGtech: Live NOW! Alexander Wischnewski of Indy Autonomous Challenge winning TUM team talking racing @diyrobocars @Heavy02011 @Ottawa…
Nov 20
Incredible training performance with Donkeycar https://www.youtube.com/watch?v=9yy7ASttw04
Nov 9
RT @JoeSpeeds: Sat Nov 6 Virtual DonkeyCar (and other cars, too) Race. So bring any car? @diyrobocars @IndyAChallenge https://t.co/nZQTff5…
Oct 31
RT @JoeSpeeds: @chr1sa awesomely scary to see in person as our $1M robot almost clipped the walls as it spun at 140mph. But it was also awe…
Oct 29
RT @chr1sa: Hey, @a1k0n's amazing "localize by the ceiling lights" @diyrobocars made @hackaday! It's consistently been the fastest in our…
Oct 25
RT @IMS: It’s only fitting that @BostonDynamics Spot is waving the green flag for today’s @IndyAChallenge! Watch LIVE 👉 https://t.co/NtKnO…
Oct 23
RT @IndyAChallenge: Congratulations to @TU_Muenchen the winners of the historic @IndyAChallenge and $1M. The first autonomous racecar comp…
Oct 23
RT @JoeSpeeds: 🏎@TU_Muenchen #ROS 2 @EclipseCyclone #DDS #Zenoh 137mph. Saturday 10am EDT @IndyAChallenge @Twitch http://indyautonomouschallenge.com/stream
Oct 23
