ArduCopter-3.2 beta testing
Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
  • Copy&paste error from AP_NavEKF.h  to    AP_NavEKF.cpp
    Git search 'AP_Float _gpsNEVelVarAccScale'
  • Hello all, i bought my pixhawk some time ago and done mandatory config and autotune. My frame is reptile 500 its a TBS Discovery clone i think. It fly well in stabilise , poshold work great but in althold its not maintainig alt. When i  fly forward it start to losing alt and i have to give a throttle up to avoid hitting ground. Flying backwards give a less drop in alt. Thorttle mid is set as  mentioned in tutorial. The firmware on pixhawk is 3.2rc13. Here are log files to tell what is going on : Log
    Thanks all for patience and any help, cheers.
      Bartek,
      Have you tried using AC3.1.5?  I'd like to confirm this is an AC3.2 issue and not a general support issue so we can keep this thread on track.
      I've had a quick look at your logs and the AltHold seems to be working pretty well.  The vehicle's pitch control is a bit wobbly (maybe autotune would help) although I don't think this should lead to an altitude loss.
      3702529058?profile=original
      • Hi Randy
        I've tried pixhawk 2.4.5 rc 13 loiter/rtl/poshold all working great but in drift mode fast forward flight like 50mph + it does lose alt badly but then regains when stopped
        Stuart
  • this is the GPS compass + Mag. i intend to use for future flights since i had been having GPS lock problems for last one month. typically it takes 19+ sats HDOP is under 1.5. this had been used buy some flyers  in this blog.
    http://www.csgshop.com/product.php?id_product=173
  • Randy (or anyone willing to answer) a quick question...
    Currently have AC3.1.1 and plan on ugrading to AC3.1.5 would like to know the following two:
    1. Do I need to do all compass&accel calibration?
    2. Would I still be able to use CLI/Terminal (I have APM 2.5) [I figured that starting AC3.2 CLI/terminal removed from APM 2.x to save dataflash space]
      Alex,
      This discussion is really for AC3.2 testing.  The answer to your question is:
      1. no need to re-do the compass/accel calibration when moving from AC3.1 to AC3.1.5.
      2. yes.
      • My apologies... Yes these questions don't belong here. However since I was away from the scene for some time, I didn't know where to ask.
        If I have more questions about 3.1.5, should I use 3.1 forum?
        thanks
  • More data for that no land issue I have.  I loaded RC13 on my TRex 550 trad.  Flew it 4 times and the first 3 were great.  The fourth did not land on the RTL.
    After a battery swap, the fifth run did not land either.  I got it to land by switching momentarily into Stab and back into Auto and it decided to land but did not disarm.
    Here is a tlog (90% is the moment it did not land). My log of the first 4 runs and my flight plan (I changed altitudes on each run).
    You can even see the video here.http://youtu.be/rkwScIGJq6U3701860233?profile=original
    2014-10-25 10-54-44.tlog
    14.BIN
    camera 1.txt
Gremsy liked Gremsy's profile
Mar 12
DIY Robocars via Twitter
Nov 27, 2022
Nov 24, 2022
Nov 24, 2022
Nov 24, 2022
Nov 24, 2022
Nov 20, 2022
Nov 20, 2022
Nov 8, 2022
Nov 8, 2022
Oct 23, 2022
Oct 23, 2022
Oct 23, 2022
Oct 19, 2022
Oct 18, 2022
Oct 13, 2022
