ArduCopter-3.2 beta testing
Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
    • T3
      Today, everything was fine again. This is good but not really satisfying... So I really appreciate any thoughts on what might have caused this behavior.
    • T3
      squilter suggested to check BRD_SAFETYENABLE. It  is set to 1.
  • Upgrading to AC3.2 Is it possible to download logs using MAVlink on the APM planner ?
    How ?
    • I do that from my pixhawk not sure on a amp
  • How to enter manually the negative compass declination or any other alternative is there ...? If any please provide. ....thank you
    yuvraj
  • Spoke too soon?? Major crash its wasted. All the $$ parts are okay though!!!! Fortunately it was just a quick wood made quad. I know I should be able to figure it out with drone share or the auto analysis on MP but I can't for the life of me get that to work not sure why. I had just turned around and was about to head home when it had a major twitch. After that it ignored my stick commands for the most part then it looked like it simply lost the ability to stay stable and fell 30-40 meters or so. I thought the battery went dead but A I had a RTL failsafe for that and B after looking at the log as far as I can tell that wasn't it. I think it was a mechanical failure but if anybody could take a look I'd sure love to know what happened.
    153.BIN
    • This reply was deleted.
      • What did you look to graph to see the FS event?
        • oh I do see the RTL and I didn't do that. But how can you tell that from the log?
            • I could not find 'volt' until I saw your post thank you that was driving me nuts. However I guess there is a glitch with AP2 as I have msg selected but nothing shows on the graph unless I'm not doing something right. Anyway I know this isn't the place for log analysis lessons but it does however seem to be the place with the most responsive members I appreciate your help. 3702873896?profile=original
