ArduCopter-3.2 beta testing
Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
  • Randy, now that 3.2 is nearing release (at least closer than it was in July LOL) the one request I have for 3.2.1 or 3.3 is the implementation of a failure recovery (failsafe) algorithm. I'm sure you are aware of the one developed in Germany ( http://youtu.be/bsHryqnvyYA ) and it sure would be nice to see it or something similar implemented in Arducopter. To have the efficiency of a quad and the flyhome safety of a hex or octa would be a dream come true. I have a cheap 450 that I'd be willing to put a Pixhawk in and do testing and filming.
    • +1
      I've been wondering when something like that would make its way to Arducopter. After losing a frame, prop and motor to a flip in auto tune due to what I believe was a sync issue, it would have been an amazing feature!
      I'm sure it would be a revolution for the majority of us with quads and hexes.
      • Seems to me it can be improved on. After all it is a tri-copter after losing one prop. Use the three forces to keep it level. Vary alternative rotating props to correct yaw. Reduce the speed to lower it down.
        • That's a great idea but the problem is the quad then becomes a grossly off balance tricopter and there is little likelihood that the remaining motors would have the power to compensate.
          • not only that but a tricopter uses mechanical roll of the tail motor to correct yaw - this cant be done on a 3 motor quad.
            but i agree main issue is balance, and the motor opposing the "dead" motor is correcting only 1 way on its legs' axis, so it cant be done (not my best explanation really).
            • Is there a better place to discuss this? Like to hear your thinking and explain mine.
      Terry,
      Yes, that would be a very cool one to do.  I'll put the equivalent for the hexacopter on the to-do list for AC3.3 but I can't make any promises.  The truth is that I can't do it on my own because I've already got too much on my plate.  Some other developer will need to do the heavy lifting.
      • Randy,
        I finally had time to check out the list. Is this the list of things for you to do, or is it a general list? If it's general it would be great if you could add the quad fail-safe too.
        I believe the same or slightly adjusted algorithm would work for both quads and hex's. I think both will require spinning for stability, only the quad will have to spin faster because it would be farther out of balance. The feedback loop for this may even automatically compensate for the difference. There is even some suggestion that a quad could survive two motors out although it sure would have to spin fast and the remaining power may only be enough lessen the decent rate. I suspect the coding would not be all that difficult and this sure would improve the safety of quads.
      • Does it mean, that a Hexa or Octro Copter based on Arducopter is not able to fly with one Motor failed?
        That is the only reason to fly more than with a quad, to have a failsafe if one Motor cuts!
        http://www.mikrokopter.de/ has this failsafe from the beginnig of providing hexa or okto Kopter.
          Andre,
          An octacopter and Y6 will fly without skipping a beat even with one motor failed.  A hexacopter may survive but as a minimum it will lose yaw control and it might flip and crash to it's death.  There's some discussion in my links above about why a hexacopter cannot revert to being a quad and keep flying.
gotham liked gotham's profile
15 hours ago
DIY Robocars via Twitter
RT @RoboticMasters: Monaco GP Circuit in the Donkey Sim (coming soon). Including buildings, tunnel and all! https://github.com/robotics-masters/sim-donkeycar-f1/tree/f1-tracks @diyr…
Wednesday
RT @breadcentric: Here are the details of #AWSDeepRacer finals: https://blog.deepracing.io/2020/12/01/aws-deepracer-league-finals-2020-round-1-schedule/ #awsreinvent2020 #AWSreInvent https://t.co/ovqsjp8V…
Wednesday
RT @breadcentric: #AWSDeepRacer League #awsreinvent2020 Open race is on Dec 1st - Dec 31st in three categories, 15 DeepRacer Evo (with LIDA…
Wednesday
RT @a1k0n: @SmallpixelCar @diyrobocars It's just something that's easy to track with chroma keying. I ended up using different colors on th…
Monday
Monday
RT @TinkerGen_: "The Tinkergen MARK ($199) is my new favorite starter robocar. It’s got everything — computer vision, deep learning, sensor…
Nov 23
Nov 23
RT @roboton_io: Join our FREE Sumo Competition 🤖🏆 👉 https://roboton.io/ranking/vsc2020 #sumo #robot #edtech #competition #games4ed https://t.co/WOx…
Nov 16
DIY Drones via Twitter
First impressions of Tinkergen MARK robocar https://ift.tt/36IeZHc
Nov 16
Our review of the @TinkerGen_ MARK robocar, which is the best on the market right now https://diyrobocars.com/2020/11/15/first-impressions-of-tinkergen-mark-robocar/ https://t.co/ENIlU5SfZ2
Nov 15
RT @Ingmar_Stapel: I have now explained the OpenBot project in great detail on my blog with 12 articles step by step. I hope you enjoy read…
Nov 15
RT @DAVGtech: This is a must attend. Click the link, follow link to read the story, sign up. #chaos2020 #digitalconnection #digitalworld ht…
Nov 15
RT @a1k0n: Got a new chassis for outdoor races (hobbyking Quantum Vandal) but I totally didn't expect that it might cause problems for my g…
Nov 11
First impressions of the Intel OpenBot https://ift.tt/36qkVV4
Nov 10
Nov 9
