ArduCopter-3.2 beta testing
Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
  • CPU load going crazy >2500%   in mission planner and APM planner.
    with firmware 3.2rc10 and 3.2rc11, if i disconnect GPS it goes down to around 15-20%
    video on bench
    Hardware : Pixhawk and 3DR GPS v2 nothing else connected
    dataflash from outside test & setup
    2014-10-05 13-43-52.bin
  • Hi,
    This version will be pixhawk modem xbee868 for me?
    Is Px4flow become active?
    Thank you in advance for your answers,
      MErdi,
      The PX4Flow is still not supported in AC3.2.  There is some active development going on so I'm pretty confident that it'll be supported in AC3.3 and it will add real value.
    AC3.2-rc11 is now available through the mission planner’s beta firmware’s link.  The changes are in the ReleaseNotes and also listed below.  Changes from 3.2-rc10
    1) reduce lean on take-off in Auto by resetting horizontal position targets
    2) TradHeli landing check ignores overall throttle output
    3) reduce AHRS bad messages by delaying 20sec after init to allow EKF to settle (Pixhawk only)
    4) Bug fixes:
        a) fix THR_MIN scaling issue that could cause landing-detector to fail to detect landing when ch3 min~max > 1000 pwm
        b) fix Mediatek GPS configuration so update rate is set correctly to 5hz
        c) fix to Condition-Yaw mission command to support relative angles
        d) EKF bug fixes when recovering from GPS glitches (affects only Pixhawks using EKF)
    It’s possible this is the final release candidate.  Personally, my only remaining concerns are:
    1. Is the landing-detector still too strict?
    2. Does it run on APM1?
    3. Is the TradHeli landing-detector change ok?
    Thanks for all your help in testing!
    • Hi Randy,
      Is the relay still supported on the APM1 boards?  I've been following the developments but I haven't actively tried anything since 3.1-rc5 and now when I try to compile I get the attached errors.  I've also attached my own little HOW TO that I've written for myself and a copy of the UserVariables.h & UserCode.pde files that I use.
      compile_errors.txt
      Showleds_ACM3.1-rc3.zip
      HOWTO Firmware.txt
        Andre,
        Yes, the Relay should still be supported on the APM1.  The issue is that there are now up to 4 relays supported so I think in your userhook_mediumLoop you just need to change the call to AP_Relay::on() to AP_Relay(0).  Also I've updated the Relay wiki page and it's got a screen shot of another parameter you'll need to set to specify which pin the relay is using.
