ArduCopter-3.2 beta testing
Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
            • Hi Randy,
              now I tried it with a different Pixhawk, one original 3dr and one clone. It is the same behavior.
              Since AC3.2 rc1 Spektrum and S-Bus is not working (ch1...4in=0). With the same setup it is working in AC3.1.5.
              I think it is mandatory to fix It!
              What can I try to figure out this issue?
            • Randy,
              I´m using the DSM-X Satellite.
              Thanks for your Help
  • I test today RC12. STABILIZE, AUTO (TAKEOFF, SPLINE and NORMAL WAYPOINTS, RTL), DRIFT, POSHOLD,  HEADFREE works without any problem. Arducopter 2.6.
  • Flight with RC12 using Droidplanner 2 and no rc at all (of course has to be switched on) - works fine exept of the twitching when copter reaches a waypoint. Is there a way to avoid this?
    Thank you for your great program - i never thought it would be so easy to inspect my fields from above.
    2014-10-11 16-09-55.log
  • Randy,
    I loaded 3.1.5 on my APM1 quad and noticed that there are no sonar readings in the MP.  I checked it in CLI and I do get a reading there.  I have enabled the sonar and I've selected XL-EZ0 in the MP.  Any ideas perhaps? Thanks,
    • Thanks Randy,
      At least I know now that's its not a bug or something I did wrong...
      Andre,
      Reporting of the sonar range to the ground station is new for AC3.2 so you wouldn't see it in AC3.1.5.  The only way to check (with AC3.1.5) is through the CLI.
  • Hello Randy and all of the Dev-Team,
    I like to thank you so much for your great work an all the time you spend. please keep going on:-)!
    Today I had several tests with rc12 (before I had rc10). Since rc10 I use EKF enabled all the Time.
    I flew in: Stabilize, AltHold, PosHold, RTL, Land, several Auto-missions with Spline and ROI, also follow-me with Droidplaner. Tested THR_FS and Batt_FS.
    Erverything works realy very fine no Failure! Great!
    Here is the LogAnalyser:
    Log File C:/Users/Andre/AppData/Local/Temp/tmp8854.tmp.log
    Size (kb) 8369.29296875
    No of lines 108703
    Duration 0:27:21
    Vehicletype ArduCopter
    Firmware Version V3.2-rc12
    Firmware Hash 6537432b
    Hardware Type
    Free Mem 0
    Skipped Lines 0
    Test: Autotune = UNKNOWN - No ATUN log data
    Test: Balance/Twist = GOOD -
    Test: Brownout = GOOD -
    Test: Compass = GOOD - No MAG data, unable to test mag_field interference <--- What does it mean?
    Test: Dupe Log Data = GOOD -
    Test: Empty = GOOD -
    Test: Event/Failsafe = FAIL - ERRs found: FS_BATT FS_THR
    Test: GPS = GOOD -
    Test: IMU Mismatch = GOOD - (Mismatch: 0.56, WARN: 0.75, FAIL: 1.50)
    Test: Parameters = GOOD -
    Test: PM = WARN - 1 slow loop lines found, max 6.55% on line 740
    Test: Pitch/Roll = FAIL - Roll (120.44, line 32834) > maximum lean angle (45.00)
    Test: Thrust = GOOD -
    Test: VCC = GOOD -
    for any interest, attached is the LOG:-)
    André
    2014-10-11 11-10-46.bin
  • Hi, question about frsky telemetry in the 3.2 which file does one need to modify to change the values been transmitted? For example, I would like to transmit hdop as power and flight mode as t2. I currently use x8r with a teensy mode, however I plan on switching that particular copter to an openLRS setup which is capable of transmitting this older frsky telemetry down to my taranis. Please advise.
    • Artem
      3.2 is now in final stages so I won't happen there as randy fix only critical bugs.
      We are trying to work with opentx for a longer term solution.
       I will try to deliver what you want before (adding hdop) before next release and releases should be shorter now.
      Once 3.2 is out , I can compile you a version with it as well. Pm me
