ArduCopter-3.2 beta testing
Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
              • Thanks Randy,
                Well I have a brushless gimbal and it just can't keep up with the fast twitch, no biggie, really I can remove it easy with a post warp stabilizer but in this smoky mountain video I wanted to show you how crazy smooth it was even without any post stabilization :-)  If we can get the twitch out in the future that would be amazing, I would not even need to post stabilize.
                You know this release has so many great features it should be a 4.0 major version release Thanks again for all the hard work to the team!
          • > do you experience the 'hickups' around the waypoints?
            Yes you can see this right at 0:23, this was my WP-5
            I usually take these hiccups out with a warp-stabilizer but I wanted to show how good the video was with spline even without any post-stablization.
            3702825188?profile=original
            • I'm curious about how 3.2 behaves with multiple ROIs.
              I see in your video that on the way from 3 to 5 the camera is on ROI 4, which makes sense. It also appears to continue looking at 4 between 5 and 6, but then it switches to a new ROI. Is WP 7 do-set-ROI? Will ArduCopter switch ROIs whenever the next WP is do-set-ROI?
              After the last ROI WP, will ArduCopter continue to face the last one, or will it use the face-next-WP/face-along-path setting? Can the operator manually take control of yaw between ROIs or after the last ROI?
              • > Is WP 7 do-set-ROI?
                Yes
                Yes
                Yes, in 3.2, I think there's a PID that can change that.
                Not that I know of without removing it from Auto, but dunno for sure.
        • Nice. :)  I'm going to have to play around with this a bit.
          -Mike
    • Im guessing you did use the Defisr as the video is clearly being stretched on the sides when you yaw...
      • Ah ok, just too bad one notices the stretching in fast panning scenes...
        • What is SuperView?
          "it uses the height of the camera's sensor that you get with 4:3 meaning that you will see more of the sky and ground assuming you are pointed at the horizon."
          This link has an image that shows how SuperView works,
          http://gopro.com/support/articles/what-is-superview
        • yeah, its just an effect that I actually wanted on this one :)
          I did another one without superview, but that mission only had one ROI, this was to show off the spline with several ROI and how smooth it was with the spline.
      • No, its raw footage, I used a GoPro black setting called SuperView.
        Well Raw except the titles and clipped the take off/landings :)
