ArduCopter-3.2 beta testing
Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
        • Quite funny, it was actually the "Check for updates" button that messed up my installation of MP 1.3.10
          Updated to 1.3.10.1 (Beta) and all is good again ;-)
  • I am running a quad on apm 2.0.    I have recalibrated after upgrading to 3.2rc10.   I  have a bad problem with GPS and AC 3.2rc10 this issue does not happen in AC 3.1.5     I have hdop under 2 and 10 sats.    Raw GPS(GPS_RAW_INT) looks good  however over time the GPS (GLOBAL_POSITION) in mission planner goes wacko swigging back and forth across the home position at ever increasing distances.     As this happen loiter becomes worse and worse until copter pitches wildly when enabled latter in flight.  I have attached telemetry and data flash log.
    2014-09-28 09-58-19.tlog
    2014-09-29 08-20-59.log
    Quad (4c).param
    https://storage.ning.com/topology/rest/1.0/file/get/3701840824?profile=original
      Dan,
      There seems to be a problem with the GPS messages (or the processing of the GPS messages).  Below are two pics one that shows good GPS message timing (Column C shows the timing and all messages are 200ms apart = 0.2 seconds = 5hz).
      3702521964?profile=original
      In your log however the timing on the messages is not increasing properly at all.  Which GPS are you using and is there anything else unusual about the GPS's connection to the APM?
      3702521400?profile=originalBy the way, it looks like the GPS Glitch protection was disabled on this vehicle.  I don't think there's ever a good reason to turn it off and it would have caught the problem immediately I think and not let the vehicle take-off or switch into an autopilot mode.
      • Thanks for taking a look and responding.    This is a APM 2.0 with internal GPS.   I disable GPS Glitch in the last flght to see if it makes a difference, it did not.   What is stange is that the copter is great on 3.1.5, no problems with Loiter or RTL.
        • From Randy:
          This issue is fixed with this commit: e7b4a02
          It turned out that a couple of missing characters meant for the SIRF GPS (which uses a very similar protocol) was upsetting the mediatek and causing it to skip the next configuration message it received. This next message happened to be the update rate.
          This will go out with AC3.2-rc11 in a few days.
  • I loaded rc10 onto my big Quad with original APM (before 3.1.5), and have flown about 20 test flights in Stabilize, Alt hold, Loiter;rtl, and Missions with roi and all are working perfectly.
    Auto flights were nice and smooth.
    But Auto Takeoff is a disaster!
    All motor goes to full throttle for a short moment and the Quad flips.
    No Problem to take off in Stabilize.
    Another small issue:
    CH6 WP_Speed tuning is not working for me.
    Sorry for my bad english.
    2014-09-28 12-58-11.log
      Thomas,
      I've made some fixes (here and here) which should ensure there's no "I-term build-up" before take-off.  This will go out with -rc11.  I'm almost confident that the next release candidate will be the last one.
      • Hello Randy
        Back from Testflight with Master.2 AutoTakeoff Tests. Automissions with Roi. The first was very good. Second test was not so good :-( 2. But not flipped.
        Thanks for your help.
        2014-10-01 14-41-43.log
        https://storage.ning.com/topology/rest/1.0/file/get/3702669364?profile=original
      • Randy, I compiled a hex with those fixes to test them in my quad ( apm 2.6) and they did not solve the problem.
        I'm I doing something wrong?
        I still had 2 situations were the copter went full right and the other went full back on auto take off.
        Please advise if I'm doing something wrong or you spot something on the log.
        Also I see that on some maneuvers the quad passes the 45 degree limit. Auto analysis confirms it. Why?
        2014-09-29 19-08-29.log
        https://storage.ning.com/topology/rest/1.0/file/get/3702669262?profile=original
DIY Robocars via Twitter
Videos from the ICRA autonomous racing workshop are now available: https://linklab-uva.github.io/icra-autonomous-racing/
yesterday
RT @SmallpixelCar: Prepared race track for Warm Spring Raceways @wsraceways and looking forward to test my new car at RAMS RC @ramsaicar fa…
Jun 6
RT @f1tenth: Trying out some nasty blocking maneuvers 🏎️🤖 #f1tenth #autonomousracing https://t.co/nMTstsaogM
Jun 5
May 27
RT @araffin2: I will talk this Saturday from 18:00 to 19:00 Paris time for the @diyrobocars community about learning to race in hours using…
May 27
RT @a1k0n: Luckily the infeasible hairpin problem was easily reproducible in simulation and I could test the fix before bringing the car ba…
May 26
RT @a1k0n: Another problem was that I was over-constraining the car's allowed accelerations, so it didn't think it could turn as tight as i…
May 26
RT @a1k0n: Breaking the map up into two halves worked, but I had to be more careful about separating the inner track from outer. There's se…
May 26
RT @a1k0n: Here's a datalog for my fastest lap of the day. Lap timer is tiny window lower-left. https://t.co/myrlWWrKUY
May 26
May 26
RT @a1k0n: Here was my car's POV. Man this track is confusing in first-person! After the incident my camera was all scuffed up and I was af…
May 23
RT @circuitlaunch: Loved seeing so many familiar (masked) faces at Circuit Launch today for our first in person @diyrobocars in over a year…
May 22
RT @circuitlaunch: Last but not least, mystery guest @BostonDynamics Spot took to the track @diyrobocars He enjoyed the #brazilianbbq too 😂…
May 22
RT @SmallpixelCar: Today’s race @circuitlaunch for @diyrobocars with @a1k0n Was busy in the morning and did not get a chance to tune camera…
May 22
RT @a1k0n: This was epic. My car was barely working this morning, had to make a lot of changes and extremely dirty hacks. Post-race analysi…
May 22
DIY Robocars @ Circuit Launch, 3/7/2020 https://twitch.tv/diyrobocars
May 22
