ArduCopter-3.2 beta testing
Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
  • I have been testing the 3.2-rc9 on my new 3DR Iris, and it is working wonderfully in all flight modes.  I did notice a couple of small issues I thought I would mention.  There still seems to be a twitch when moving through circular waypoints.  I haven’t noticed the twitch using any other regular waypoints, but if I do an auto circular waypoint mission in Mission Planner it twitches significantly at each waypoint.  The other small issue I found was if you put WP_NAV_SPEED on channel 6 then the auto modes won’t move.  It seems as if the speed is set to near 0 even though I set min and max parameter values for channel 6 at 500 and 1000.
  • this is bug? sonar on arducopter-3.2 rc9?(pixhawk)
    1.62v=1.62*204=3.89m, why is -323.66??
    but ,voltage is lower than 1.5v normal, as shown in figure; this is bug?
     3691151870?profile=original
    3691151756?profile=original
    • I am having same sonar scaling issue, sent Randy logs a week or so ago... He is busy! I can repost if it would help...
      • hi Mike feldmann, this no bug,but wiki error,Scaling =2.04 is ok!(wiki: scaling=204 this is wrong,unit=m)
      • i am download ardupilot code ,try find for this problem!
  • UPDATE to Dual GPS.  I received my MAX-M8Q GPS and immediately soldier head pins to it and hooked it up to my Pixhawk.  Ran a bench test all night and this morning looked at the status menu on the Mission Planner and noted that while the LEA-6H GPS held steady at 10 satellites with a HDOP around 1.5, the Max-M8Q was locked onto 18 satellites with a HDOP of 1.1.
    Next step is to conduct a few flights and I will attach logs for DEVs to review.
    More to follow.
    • I will be very interested to hear your results!
      I have seen almost the identical stats you saw comparing the two gps's. However I must say I'm a bit surprised I haven't seen a huge increase in physical accuracy. Even with 13-14 sats and an HDOP of 1.4 I saw drifting  2-3 meters sometimes. Not often but sometimes. 1 was more the norm. I only had 3 flights on the same evening though .... I know it can vary a bit day to day.  It seems the biggest advantage to the Ublox 8 is the acquisition times. On a hot restart I often have 8-9 sats by the time the pixhawk gets done booting up. Nice!  But if I bought it strictly for position accuracy.. so far I'd be disappointed.
      • I think you have to keep in mind that the level of accuracy won't be in centimeters of accuracy but at best 3-4 meters.  With that being said there are commercial satellites like Omnistar that sells access to their satellites but I do not think anyone could afford it other than big business.  What I have seen is that the vehicle has become rock solid in position albeit off as much as a few feet from where it sits.  I'm pleased with the fact that I have not seen much drift when coupling the M8Q with the LEA-6H GPS and to me that is more of what I seek.
        For those who wish to have pin point (centimeter) accuracy I think you will be disappointed.
