ArduCopter-3.2 beta testing
Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
      • Please take a look at this log as well and the fact that there is a GPS dip each time the crash happens while baro-alt stays normal raises question
        2014-10-03 17-12-34.log
        • 3702768641?profile=original3702768828?profile=originalPLEASE LOOK AT THE GPS DIP!!!
  • Please help me to fix one problem...
    GoPro video shows some vertical jumps while moving forward at alt-hold and poshold modes. Please tell me that parameters should I tune to correct this ?
  • And now for something COMPLETELY different....Is Spline Way Point working properly in RC10? ... and now we return to our regularly schedule programming :P
      Thor,
      Yes, it works.  The only thing I'd say is that it does have a small twitch as it passes through a spline waypoints if the WPNAV_SPEED is set to 10m/s or higher (actually I'm not sure of the exact speed where it appears).
  • Today i am going out to test some things on my RC10 Release, is Spline_Waypoint Now working properly? I am wanting to test DO_SET_ROI  with Spline Waypoints around a tree as a target.
    Also going to try out Follow ME in Droidplanner but disappointed in the changes in the software that it appears almost hidden in the Auto options.
    Also for any N00BS out there like me, i discovered that you cant find follow me until you are armed. once armed and before you select Auto to get to Follow ME, be aware my motors spun up unexpectedly, even tho my MOT_SPIN ARM is set to 0. Luckily i had my props off for safety.
    i am guessing Droid Planner assumes you are already in the air when you click Auto. i am glad i took my props off while i was looking into this, i was in my house at the time because the cursed florida weather has left me grounded for a couple weeks. I am only mentioning it here because this is the most popular thread on Beta Arducopter.
    Hopefully this will be fully communicated out to all and no one has to discover this like i did. this could have been disastrous for the less experienced.
    • I don't think you have to be in auto to start FM. I didn't I was just in loiter. re- took off... maybe your throttle wasn't low when you hit uto
      • Auto only appeared when the quad was armed in the 2.7 RC2 version of Droid planner, i dont want to hijack this thread, i just wanted to make sure thsi was noted some where on a popular thread, if i made the mistake of any kind others will too :)
        • must press takeoff before follow me.
          • got it, it worked great today, so thank you!!
