ArduCopter-3.2 beta testing
Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
      • Thank you Randy for the response.
        I did the Ctrl-F and nothing seemed to happen.
        I logged into the console of the Pixhawk and figured out the syntax to change CIRCLE_RADIUS parameter directly.  When I go back to mission planner the new value does display.
        CIRCLE_RADIUS in Mission Planner still states the units are in Meters and the range is from 1 to 127.
        I'll have to take notes on other parameters I see in Mission Planner that state out of range.  The only other that comes to mind right now was Stab_PIT and Stab_RLL P parameters.  Autotune had set those values to something like 8.1 - range in Mission Planner is from 3 to 6.
        Interesting the question pops up stating value is out of range are you sure?  If you click yes - nothing happens the value stays as it was before.
        I'll use the terminal to work around - I'll try testing more today with missions.  I'm sure Mission Planner software will catch up soon enough.
  • Randy,
    Mentioned this a few posts back that I was seeing un-requested throttle out commands causing rapid assent of quad with following specs:
    APM 2.5 (now using external mag/GPS)
    SunnySky 4110S-25 340KV motors
    HK Multistar 45amp ESC running SimonK firmware
    Props - 16x5.5 CF
    Battery: 6S 5000mAh Zi[ppy Lipo
    I have since done a manual tune on the frame but continue to see un-requested throttle out commands.  I have attached a couple of logs for you to review, as well as posted another video demonstrating the behavior.  Is this just a tuning problem?  Video can be viewed here: http://youtu.be/Bd8T1vNVUWk and the "throttle bump" occurs at 2:05 and again at 2:41 and 3:03.  During the first two I did not touch the throttle stick and both times it appeared to descend back to its initial altitude.
    Jim
    2014-10-17 13-52-36.log
    2014-10-17 13-41-32.log
    • Randy,
      I believe that I have solved the problem.  Mounted the APM on Zeal Gel and nylon tie (covered in fuel tubing) strapped it down.  Just finished re-testing in post Hurricane Gonzalo winds (41 gusting 53 km/h) and quad held really well in both AltHld and PosHld.  Excellent work developers!!!
      2014-10-19 18-12-32.log
    • Randy,
      Thanks for the feedback :) I just wanted to make sure that it had nothing to do with the motor "pulsing" fix that you implemented a few rc's back, as this is the same frame that was encountering that problem.  I will focus on reducing vibes and seen if that helps.  FYI, I have attached a vibration graph from the same vehicle from earlier testing (I have not made any changes in mounting between then and the recent log attached above, so I would assume that vibs are similar).  Will keep you informed.
      https://storage.ning.com/topology/rest/1.0/file/get/3702526914?profile=original
      Jim,
      I strongly suspect it's high vibration levels.  The IMU logs aren't enabled so we can't see the accelerations directly but the Baro alt and Inertial Nav alt diverge by over 5m a few times and also around 2min there's the classic symptom of high vibration which is Altitude climbing but the climb rate goes negative.  This contradiction comes when inertial navigation is unable to correctly blend the accelerations it's seeing with the absolute barometer readings.
      3702526659?profile=original3702526512?profile=original
  • @randy is pixhawk suport the px4flow now
      @uavfans,
      Not yet but it's under development.  A few commits went into "master" (which will become AC3.3) a couple of days ago which allow AC to pull data from the sensor.  Paul R from the dev team has already been performing some flight tests.  It'll take a bunch more work but I'm sure it'll be in AC3.3.
  • Regarding parachute, I have a problem with servo init. When APM initializes, rc_out on parachute is set to 900, whatever is my setting on Chute_servo_ON/OFF.
    I tryed to add a line in radio.pde to do RC_Channel_aux::set_radio(RC_Channel_aux::k_parachute_release, _servo_off_pwm) but it doesn't change anything.
    • Thanks. I will make some extensive test with parachute fonctionnality even if it is at bit scary :-)
      Manu,
      Thanks very much for testing this out.  Not many have played with the Parachute functionality yet.
      I've tested and you're right.  The servo is not being initialised to the off value.  I'll fix it and let me think about whether we need to include this fix in AC3.2 or not.  A workaround would be to always use 900 as the off value although obviously that's not idea.
DIY Robocars via Twitter
RT @TinkerGen_: "The Tinkergen MARK ($199) is my new favorite starter robocar. It’s got everything — computer vision, deep learning, sensor…
5 hours ago
5 hours ago
RT @roboton_io: Join our FREE Sumo Competition 🤖🏆 👉 https://roboton.io/ranking/vsc2020 #sumo #robot #edtech #competition #games4ed https://t.co/WOx…
Nov 16
DIY Drones via Twitter
First impressions of Tinkergen MARK robocar https://ift.tt/36IeZHc
Nov 16
Our review of the @TinkerGen_ MARK robocar, which is the best on the market right now https://diyrobocars.com/2020/11/15/first-impressions-of-tinkergen-mark-robocar/ https://t.co/ENIlU5SfZ2
Nov 15
RT @Ingmar_Stapel: I have now explained the OpenBot project in great detail on my blog with 12 articles step by step. I hope you enjoy read…
Nov 15
RT @DAVGtech: This is a must attend. Click the link, follow link to read the story, sign up. #chaos2020 #digitalconnection #digitalworld ht…
Nov 15
RT @a1k0n: Got a new chassis for outdoor races (hobbyking Quantum Vandal) but I totally didn't expect that it might cause problems for my g…
Nov 11
First impressions of the Intel OpenBot https://ift.tt/36qkVV4
Nov 10
Nov 9
Excellent use of cardboard instead of 3D printing! https://twitter.com/Ingmar_Stapel/status/1324960595318333441
Nov 7
RT @chr1sa: We've got a record 50 teams competing in this month's @DIYRobocars @donkey_car virtual AI car race. Starting today at 10:00am…
Nov 7
Nov 6
RT @a1k0n: Car's view, using a fisheye camera. The ceiling light tracking algorithm gave me some ideas to improve ConeSLAM, and having grou…
Nov 5
RT @a1k0n: To get ground truth I measured the rug, found the pixel coordinates of its corners, calibrated my phone camera with my standard…
Nov 5
RT @a1k0n: @DIYRobocars is back in December, but outside. Time to reinvestigate ConeSLAM! I rigged up a quick and dirty ground-truth captur…
Nov 5
