ArduCopter-3.2 beta testing
Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
        Giuseppe,
             The method that's implemented in the mission planner only spins the motors at a low level (13% i think) for a short time.  The arducopter side is very simple though and it does allow the ground station to spin the motor at whatever speed it wants for as long as it wants so it's really up to the ground station developers.  The mission planner issues list is here.  I can't comment on when MichaelO would get to the request of course, that's up to him.
      • I can't find motor test in MP.
        "Individual motor tests (see MP's Initial Setup > Optional Hardware > Motor Test)"
        the only option available is "Compass/Motor Calib"
          Jay,
               It should be there but perhaps it's only the Beta version of the mission planner or maybe only in the  "Advanced View".  Both those options can be selected by going to Config/Tuning > Planner and check the "Beta Updates" and/or "Advanced View" checkbox.
          • the CLI still here by the way.
    Wow, exciting! So many improvements and new features confirms ArduCopter as an absolutely outstanding firmware, thanks and well done for all the hard work in getting this all implemented and tested!
    You guys should be proud.
  • Awesome work Randy and the rest of dev team! Look forward to testing out new features and improvements!
  • This reply was deleted.
      Barrett,
           We've had to remove the CLI because we were running out of flash space.  Instead you can download the logs from the MP's Flight Data screen's DataFlash Logs tab.
      3702490736?profile=originalThe CLI's motors test has been moved to the MP's Initial Setup > Optional Hardware section.
      The CLI's reset (which resets all parameters to their factory values) has been moved to the Config/Tuning > Full Parameter list.  Although when I tested it a couple of days ago that wasn't working (it's a mission planner issue).
      • Is it possible to download the tlogs with APM planner ? How ?
      • Running out of Flash space already ?? I thought the whole idea with the pixhawk we have tons of headroom for development ?
        • he is talking about APM...
