ArduCopter-3.2 beta testing
Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
        Steve,
        Based on your previous posts, it looks like you're a new user to arducopter.  That's great of course but you should definitely stick with the nice and stable official firmware which is AC3.1.5.
        The First Time setup wiki is here which might help you get started.
        Alternatively if you have a dataflash log I can have a look at your flyaway issue.
        • Yes, Im a beginner. I cant use 3.1.5 because I have S.BUS problems.
  • Dear sir : whould you please read this
    _____in  ArduCopter 2.x (traditional heli) (224) _____About ::
    APM Heli V3.15 vs V2.73 _ The most we holp is :::
    I holp 2.73 add INS_MPU6K_FILTER is the best ...
    http://diydrones.com/forum/topics/apm-heli-v3-15-vs-v2-73-the-most-...
  • 3.2RC4, fly very well.
    Thank you for development staff.
    https://vimeo.com/103391672
    • That is smooth. I was going to wait for a final 3.2, but I'm finding it hard to resist flashing this.
      Anyone been flying rc2, 3, or 4 with a Y6B and APM 2.6? How is it?
  • Is there a list of changes from the latest stable to the 3.2rc4?
  • Need some help with this one please...
    - Load 3.1.5 (no cal, no wizard, nothing but software load...).  Apply LiPo power, all ESC's beep:  beeep-beeep-beeep - beep-beep - followed by single ongoing beep, all motors wiggle.  Arms and flies normally.
    - Load 3.2-rc4 (no cal, no wizard, nothing but software load...).  Apply LiPo power, 1 ESC beeps:  beeep-beeep-beeep - beep-beep - followed by single ongoing beep, only that motors wiggles.  Arms but only one motor turns.  Disconnect / reconnect LiPo, 4 ESC do beeep-beeep-beeep  (no double beep, no ongoing beep), but that's it...  Arms but motors will not turn.
    - Reload 3.1.5, all operations normal, flies perfectly with no cal/wizard, etc...
    How can software loads affect the ESC in this manner?
