ArduCopter-3.2 beta testing
Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
      • Hi, Rich B
                 Now, I got the same issue "Initialising  APM" with pixhawk, How did you solve it? can you help me?
                 Thanks!
        I think the issue is that the board is not in a good state immediately after uploading the firmware.  It's best (perhaps required) to power off/on the board after a firmware update.
        I think your board is fine.
    • I thought EKF smoothing will be included in this release. :(
    • After upgrading to 3.2rc7, I'm not able to choose "Position Hold" flight mode in Mission Planner -> Flight Modes - no fm value on the combo box list. Full parameters page also does not show this flight mode in options column.
      • Missed PosHold after upgrading to rc7???
        • Strange... I checked - PosHold is in place.
          • After reinstallation of MP from *.msi package, I have "Hybrid" mode on the list. Should it not be "PosHold"?
            • Hybrid / PosHold - the same.
              • I know that, but I thought that changing naming convention from Hybrid to PosHold is permanent.
                  It's because the .msi package is not updated with each mission planner release.  So when installing from the .msi you actually end up with an older version of mission planner.  If the Help screen's "Check for Updates" button is pushed it should update to the latest and PosHold will reappear.
Aug 25
