ArduCopter-3.2 beta testing
Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
  • Hi Randy,
             first of all congratulate you for the excellent work you do for the community of UAV, and patience with us newbies like me.
    I have a question. I installed arducopter 3.2 released in my hkpilot32 / gps ublox 8m and watch one erroneous reading cpu load on average 60% with peaks of 2500%.
    Readings's done with the "mp 1.3.15" and "planner 2.0.15" and is the same values 60% with peaks of 2500%.
    The funny thing is that if I disconnect the GPS readings return to 20% cpu load.
    In the arducopter 3.1.5 cpu load is 11% with the same hardware.
    Thank you very much
    Damian
    • Hi Richard when I connect the fc hkpilot32 and gps not acquired satellites is 20% when sat fix rises to 60% and peaks begin 2500%
      Thank
      Damian
        2500% seems pretty odd.  I'm sure we can't have more than 100% so it seems like some kind of reporting error.
        The CPU utilisation of AC3.2 is a bit higher than AC3.1.5 as we've added new features but even with AC3.1.5 it was still running at very close to 100% when flying in loiter mode.  I wouldn't worry about it too much unless you're seeing issues in flight.
        • Hi Randy / Richard
                            I wanted to comment that i was seeing many tlog of droneshare.com and those PX4 have peaks at 2500% load,
          which as Randy says would not have to worry. config my rct800 and went out to fly, as we say in Argentina fly "Re Bien" (very good)
          Test Stabilize, AltHold, Loiter and PosHold.
          Again thank you very much to everyone for making this a reality.
          Regards
          Damian
    • @Damain
      got this answer from Randy 5-6 weeks ago
      http://diydrones.com/xn/detail/705844:Comment:1800261
      The high peak in load starts when code get a gps fix or amount sat (or both)
      i have no spare time to investigate it, to busy at work.
  • Hello Randy
    Many thanks for the excellent work for 3.2
    please tell me where can I download the version 3.1.5.
    in the MP is only 3.1.4
      @Rainer,
      Aha, MP isn't showing AC3.1.5.  I've ping'd a note to Michael to add it.
    Please note that 3.2 has been released http://diydrones.com/profiles/blogs/arducopter-3-2-released
    • Sorry, isn't a good idea, when a firm become stable, to close beta post? so we write in only one post and is easier for developers to follow owr questions from only one post and not for two with include the same matter ? for me this forum is great, as you prefer, I learn a lot, this only a little idea to help with a drop in the ocean, thank's very much appreciate this forum.
      • sorry i like this project and respect the dev's but this Forum is some what chaotic, how can the Dev's work with this i don't understand. A Lot of input isn't seen by anybody while tasks aren't structured.
        it's like hand free driven.
