ArduCopter-3.2 beta testing
Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
            • Hi Alex,
              I don't want my flight batteries drained while doing essential ground based tasks, that is why I do it as above.
              As I said, never had problems, yet :-)
              • I see your point. Yes it is a good way to keep the flight packs fresh. I never thought that way.
                What type of ground test you perform? Did they require the motors to spin?
                • Hi Alex,
                  This is on a fixed wing.
                  I check the HUD, GPS lock, load or check the mission, different modes, briefly run the motor.
                  Yes, can be done with the normal flight pack, difference is, if there is a problem, the quad might crash < 15 minutes away, the plane 120 minutes away, at three times the speed :-)
        • Hi Martin.  I'm guessing you're running the two packs in parallel?  If so why dont you just wait for the gyros to calibrate before you plug the 2nd battery in...?
          • Yes that was my solution too, worked fine as long as I remembered to do that.
            What are people doing if the battery is mounted underneath, and the copter also needs to be turned upright before the cal starts.
            Is there usually enough time ?
          • @Andre,
            Good idea, I've had that problem before too but didn't realize that I was the cause of it. I'll wait to plug in the 2nd battery from now on!
  • @Christian, @Thomas, I had just bought a new uBlox M8N GPS receiver. i understand that baud rate and SPI has to be changed before i connect it. can u pls share how to change these settings on new M8N GPS before connecting to Pixhawk GPS port. is there a utility for changing the GPS settings. i think baud rate has to be 38400
  • Hi Randy,
    I noticed in the Datalogs produced by v3.2(rcX) has dropped the FMT line for "MOT" (for motors). Was there a reason behind this? It was very useful for detecting how many motors were attached even when no logging was taking place for the motors.
    For example, from v3.1:  FMT, 11, 11, MOT, hhhh, Mot1,Mot2,Mot3,Mot4   = 4 Motors, or FMT, 11, 19, MOT, hhhhhhhh, Mot1,Mot2,Mot3,Mot4,Mot5,Mot6,Mot7,Mot8  = 8 motors.
    Is there another way of detecting the number of motors in the datalogs?
    Cheers
    Kev
      Kev,
      The info is all still there but it's been renamed from MOT to RCOU (i.e. RC Out) to make it consistent with Plane.
