ArduCopter-3.2 beta testing
Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
  • Hello,
    I have altitiude hold issue on my quadrocopter, i use the beta software from rc1 and on all versions my copter is randomly going up or falling down. The movie was recorded on rc14.
    Here is the video: http://youtu.be/FtLv9zNwBmI?t=10m (starts at 10min).
    Log: http://www.speedyshare.com/v4xcQ/26.BIN
    Same issue on APM 2.6 and PIXHAWK 2.4.3 on two quadrocopters.
      Ficu,
      I had a look at the logs and it's definitely vibration levels especially when the throttle is very high.
      3702531556?profile=original
      • But on ArduCopter 3.1.5 all is working great. Yesterday i tested other and smaller props and i still the altitude hold working bad. The vibrations are same.
        Bug in AC 3.2 is revealed that I fly straight and set the pitch to mid, next the quadcopter is going up and for many seconds going down.
        I make movie with the issue on rc5 and APM.
        Video: https://www.youtube.com/watch?v=aIxEOK01bes
        On 0:27 i set the pitch to the mid position, and the quadcopter is going up, i tried to set throttle to lowest position and i have not control the altitude. The movie is on AltHold. Same issue is on the new version of AC 3.2.
        1:27 same issue.
    • what is a Pixhawk 2.4.3?
      -Mike
        There's one very big difference between the 2.4.3 and the 2.4.5 though and that is the addition of a 2nd IMU, the MPU6k.
        • Randy you mean from 2.3 to 2.4. From 2.4.3 to 2.4.5 there was no mayor change, just some different capacitor values :). 2.4.6 will add some redundancy for naughty rc receivers that misbehave.
        • I check it and i have on the board MPU6000.
      • Its just the board revision number of the Pixhawk. Small changes needed are done to the board and released to the newest customers. There are 2.4.3, 2.4.5 and the latest 2.4.6 (isnt out i believe).
  • @randy, i upgraded to AC3.2-rc14 with APM2.6. i ran a auto tune since i had increased the prop size to keep the throttle in mid position. after auto tune while in loiter mode the craft suddenly starts climbing. this happens after 2 minutes of hovering in loiter mode. it happened even during a mission. this was not occurring before the auto tune. luckily the craft was in line of sight and i brought it back safely. this  is the first serious issue i had with my quad since AC3.0.1. so i think some issue is there in auto tune.
      Yes, I agree with Johnex.  It's unlikely to be directly related to AutoTune and much more likely to be related to the vibrations on the Z-axis.
      By the way, the dangerous climb due to Z-axis vibes is the #1 issue we will try and fix in AC3.3.  The EKF already does a much better job of handling these situations so the effort is mostly just to make sure the EKF is fully integrated, stable, etc.
Gremsy liked Gremsy's profile
Mar 12
DIY Robocars via Twitter
Nov 27, 2022
Nov 24, 2022
Nov 24, 2022
Nov 24, 2022
Nov 24, 2022
Nov 20, 2022
Nov 20, 2022
Nov 8, 2022
Nov 8, 2022
Oct 23, 2022
Oct 23, 2022
Oct 23, 2022
Oct 19, 2022
Oct 18, 2022
Oct 13, 2022
