Warning #1: PX4/Pixhawk users upgrading from AC3.1.5 (or earlier) may need to re-do their compass and accelerometer calibration because AC3.2 also uses the backup compass and accels. Pre-arm checks have been added to ensure this has been done.
Warning #2: on the APM2.x the logs must be downloaded using MAVlink instead of the terminal.
AC3.2-rc14 is now available for BetaTesters through the mission planner’s Beta Firmwares link. The full release notes can be found in ReleaseNotes.txt and changes from -rc13 can be seen below.
It’s a big release with “the onion” restructure and a bunch of new features (including these 57 closed items) so we need to re-test almost everything including all flight modes, all mission commands and all the new features. Marco and I will be maintaining (and adding to) this testing list. Issues reported will first be checked by Jonathan, Marco and I and then confirmed bugs/issues will be put on the github issues list (and then hopefully fixed).
Thanks especially to the beta testers who put their copters at risk testing each release. Enjoy!
Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
Never know, I was in stabilize mode. Will try to get the logs if I can, PX4 is beat up pretty bad. Copter hit an overhead water pipe in my studio. Might sound insane to test inside but imagine if this was outside! Yikes!!!
Here is the log. Found at least three errors: Flightmode 4, Failsafe Fence 1, AFE Fence 1. I attached the log. BTW, I never invoked the land command.
2014-06-12 14-26-34 16.log
Hope someone can shed some light on this issue as I really want to get in the with 3.2...just not like this. :-) Well this is what the test quad was built for and adventure was had by all.
Andy,
I had a look at your logs and something went very wrong with the inertial nav altitude. The scale is not great in the image below but in any case, the inertial nav altitude estimate is in green. It bounces around between +20 and -60m for the first couple of minutes and then it shoots up like a rocket to 2.9km and then drops again to -600m. This is certainly the cause of the behavior you saw:
a) When the alt climbed above 100m it triggered the altitude fence and switch to LAND mode. Because it thought it was climbing it reduced the motors to their minimum and you saw the vehicle come down. Even though your throttle was at zero, it didn't automatically disarm because it didn't think it had landed (because the climb rate >500m/s).
b) when the inertial nav alt peaked and started falling, the vehicle now tried to slow it's descent by ramping up the motors and then it crashed into the ceiling.
We don't have a chorus of people running into this because most users of PX4/Pixhawk are new and so they wouldn't be carrying over their parameters from AC3.1.
Thanks Randy! Always good to know exactly what caused something. Would a full recalibration be ok or should I hold off on trying 3.2 on this PX4 again?
Cheers,
Andy
Frank. The only thing I tried was to go back to 3.1 but the quad flew terribly. The impact made contact between the PX4 and a water pipe. Not sure if the PX4 is toast. Will do a few more tests first.
Thanks for your update.
Cheers,
Andy
Andy, did this work for you? I'm also having issues with altitude on PX4/PX4IO, even in 3.2-latest of june 11th. My report is on page 37 of this thread. In EKF-mode the altitude sticks at 15000 meters after a few minutes and in 'legacy'-(non-EKF) mode the altitude drops to a steady 0 meters after a few minutes.
And also @Randy: I was under the impression that PX4 does not have a backup accelerometer. After calibration in 3.2 (latest and rc2) INS_ACC2* all are zero.
Thanks for looking in to this!
Andy,
I think if you connect your px4 as it is now (i.e. without the backup accels being calibrated) to your PC with the USB cable you'll see the altitude (via the mission planner) move all over the place especially if you lean the board.
If you re-do the accel calibration and repeat the test I think it'll be a-ok.
Thanks again for this important report.
been having a lot of fun with 3.2, both on a quad and y6. hybrid is fantastic!
here's a vid, taking too much risk with release candidate software but I believe in it lol.
Nice place(where is it if not a secret?),nice confident video
