ArduCopter-3.2 beta testing
Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
        • Never know, I was in stabilize mode. Will try to get the logs if I can, PX4 is beat up pretty bad. Copter hit an overhead water pipe in my studio. Might sound insane to test inside but imagine if this was outside! Yikes!!!
          • Here is the log. Found  at least three errors: Flightmode 4, Failsafe Fence 1, AFE Fence 1. I attached the log. BTW, I never invoked the land command.
            2014-06-12 14-26-34 16.log
            https://storage.ning.com/topology/rest/1.0/file/get/3702823376?profile=original
            • Hope someone can shed some light on this issue as I really want to get in the with 3.2...just not like this. :-) Well this is what the test quad was built for and adventure was had by all.
                Andy,
                      I had a look at your logs and something went very wrong with the inertial nav altitude.  The scale is not great in the image below but in any case, the inertial nav altitude estimate is in green.  It bounces around between +20 and -60m for the first couple of minutes and then it shoots up like a rocket to 2.9km and then drops again to -600m.  This is certainly the cause of the behavior you saw:
                   a) When the alt climbed above 100m it triggered the altitude fence and switch to LAND mode.  Because it thought it was climbing it reduced the motors to their minimum and you saw the vehicle come down.  Even though your throttle was at zero, it didn't automatically disarm because it didn't think it had landed (because the climb rate   >500m/s).
                    b) when the inertial nav alt peaked and started falling, the vehicle now tried to slow it's descent by ramping up the motors and then it crashed into the ceiling.
                3702897493?profile=original     I've never seen this but I think the cause is your backup accelerometers haven't been calibrated.  We've added support for redundant accelerometers and gyros but we have not extended the pre-arm check to ensure that both are calibrated so we better add that!
                     We don't have a chorus of people running into this because most users of PX4/Pixhawk are new and so they wouldn't be carrying over their parameters from AC3.1.
                3702897097?profile=original     I'm very sorry for your troubles, we will confirm this is the issue put a warning at the top of this thread to tell people to redo their accel calibration and fix it for -rc3.
                • Thanks Randy! Always good to know exactly what caused something. Would a full recalibration be ok or should I hold off on trying 3.2 on this PX4 again?
                  Cheers,
                  Andy
                  • Frank. The only thing I tried was to go back to 3.1 but the quad flew terribly. The impact made contact between the PX4 and a water pipe. Not sure if the PX4 is toast. Will do a few more tests first.
                    Thanks for your update.
                    Cheers,
                    Andy
                  • Andy, did this work for you? I'm also having issues with altitude on PX4/PX4IO, even in 3.2-latest of june 11th. My report is on page 37 of this thread. In EKF-mode the altitude sticks at 15000 meters after a few minutes and in 'legacy'-(non-EKF) mode the altitude drops to a steady 0 meters after a few minutes.
                    And also @Randy: I was under the impression that PX4 does not have a backup accelerometer. After calibration in 3.2 (latest and rc2) INS_ACC2* all are zero.
                    Thanks for looking in to this!
                    Andy,
                         I think if you connect your px4 as it is now (i.e. without the backup accels being calibrated) to your PC with the USB cable you'll see the altitude (via the mission planner) move all over the place especially if you lean the board.
                         If you re-do the accel calibration and repeat the test I think it'll be a-ok.
                         Thanks again for this important report.
  • been having a lot of fun with 3.2, both on a quad and y6. hybrid is fantastic!
    here's a vid, taking too much risk with release candidate software but I believe in it lol.
    • Nice place(where is it if not a secret?),nice confident video
DIY Robocars via Twitter
20 hours ago
Saturday
Saturday
Saturday
Wednesday
May 8
May 8
RT @SmallpixelCar: Test my car. RTK GPS worked great. Thanks @emlid for their support. https://t.co/EkQ6qmjmWR
May 8
DIY Drones via Twitter
RT @chr1sa: @kane That's @diydrones circa 2009. Still have a box of those Canon cameras that we used to strap into planes, just like this.…
May 3
RT @chr1sa: Our next @diyrobocars race is going to be outside at a real RC racetrack in Fremont on May 28. Fully autonomous racing, head-to…
Apr 30
RT @f1tenth: Our Spring 2022 F1TENTH course @PennEngineers is coming to an end with a head-to-head race as a big finale. So proud of our st…
Apr 26
RT @DanielChiaJH: I wrote a thing! Throughout the development of my @diyrobocars car I've been using @foxglovedev Studio to visualize and d…
Apr 23
RT @SmallpixelCar: My new car for high speed. Low body, everything ( @NVIDIAEmbedded Jetson Xavier NX, @emlid RTK GPS, IMC) under the deck…
Apr 23
Apr 21
RT @f1tenth: F1TENTH Race training setup @PennEngineers for our upcoming ICRA2022 @ieee_ras_icra competition. @OpenRoboticsOrg @IndyAChalle…
Apr 21
RT @fatcatFABLAB: Proud to be hosting a restarted DIY Robocars NYC Meetup April 26. Come by if you want to talk about and race self-driving…
Apr 17
